15-08-2008, 07:39 PM | #1 | ||
Smile
Guys..I am thinking about gving the wagon a new rev limit at 7000rpm.Am I mad? What gives at higher engine speeds? What will I break?Will I break anything?
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
15-08-2008, 07:43 PM | #2 | ||
Sly like a G6
I heard years ago some mob in Brisbane were making DOHC heads for AU's (before the BA came out) and their engines redlined at 7000. I have NFI if they did anything to the bottom ends though.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
15-08-2008, 08:00 PM | #3 | ||
justa6
you would have to have one hell of an angry na motor for it to be of an advantage i would think
15-08-2008, 08:15 PM | #4 | ||
Smile
I know the ba sixes damage oil pump gears start to give way around 6k. I dunno lets see what breaks...
15-08-2008, 08:20 PM | #5 | |||
Smile
15-08-2008, 09:40 PM | #6 | ||
Wizard Member
Do you have a built bottom end with new rods? I'd say you will probably throw a rod at those sort of revs in a AU six..
Frosty and FPR - Bathurst winners 2013 |
15-08-2008, 09:43 PM | #7 | |||
15-08-2008, 09:58 PM | #8 | ||
not here much anymore
Rev it until it blows up then subtract 500rpm = safe limit
2024 F150 XLT
15-08-2008, 10:01 PM | #9 | ||
www.TUFFCARPARTS.com
Stav, mate stop clutching at straws and just boost it, or get a better base for quick times!
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
15-08-2008, 10:02 PM | #10 | ||
around the place
thats your best bet. au motors are only a couple hundred $ anyway...
You will find the rods / rod bolts will give way at those rpm. the 4.0's have a long stroke which makes piston speed very high
GPS Tracker for your vehicle - PM me for info |
15-08-2008, 10:08 PM | #11 | |||
Afterburner + skids =
15-08-2008, 10:17 PM | #12 | |||
Sly like a G6
When BA production started, Ford finally conceded that the days of pushrod 6's were over, and redesigned the block that still had provision for an in-block camshaft right up until the AU was phased out! The BA's oil pump drive is known to be fragile, I think you'll find the AU's is pretty robust. Your biggest issue would be electrical problems... due to conrods knocking the alternator or starter out of the engine bay
15-08-2008, 11:06 PM | #13 | |||
Boost Addict
i think one of the biggets problems by the end of the day is the bore vs stroke issue. the AU is a square engine, meaning the bore is as wide as the stroke is long, which gives the 4l its torque characteristics. But that comes at the price of reduced revability. The problem in itself is piston speed, due to the massive amount of travel the piston has to do to complete its full stroke, the amount of friction between piston ring against bore would create emense heat. Plus ,with the added speed, the forcesthe gudgon (piston) pin would have to withstand would be nuts. i would say it would tear the gudgon pin clean out of the piston at full song. if we look at the engine characteristics of a RB or 2J engine, basically "similar" in design, the stroke is not anywhere as long as the one of the 4l. thats what allows those engines to do the revs they do (plus the added head flow characteristics and DOHC). Anyway while i am rambling, to overcome these issues, of course stronger internals (pistons, conrods and pins) but also blue printing and a good balance, would allow you toe rev the engine beyond its normals rev range. BTW sly the blokes you are talking about is crocdale in Townsville, i spoke to him just after he released the prototype in his sons AU. he offered me a second head, but i didnt quite had the cash for it. it was still a 12 vakve head but twin cam, in quite refined flow design of the head and bigger valves. Same bloke was heavily involved in the twin cam head developments for the BA. from what i know he is in england now ...
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO Can't live with it, can't live without it! |
16-08-2008, 03:02 AM | #14 | |||
Jim
HAHAHAHA lmao......... classic
The Daily. White 2017 ZG Escape TDCI AWD Wagon The Wifes. Grey 2015 MD Mondeo TCDI Hatch The Old Daily.......2003 Octane BA Taxi Pak Egas Falcon Build Thread |
16-08-2008, 07:34 AM | #15 | ||
Smile
Hmm.So the blocks would go bung eh? After my first posting I had flicked through my manuals and noted that even the standard xr6t boosted cars have peak power at around 5200 rpm.The vct i6 au and hp motor peaks at 5000rpm. Without making premature assumptions it does seem these motors wont make much more power past this rpm area. Sure we can make the cars somewhat faster based on revs but then the cost of blowing an engine and fixing it seems to be a waste.
If say my power too peaks around 5000 to 5500 rpm then my current limit of 6250rpm is about right. Perhaps a slightly bigger convertor from the 2500 rpm unit to 3500 would be a wiser investment.
16-08-2008, 07:35 AM | #16 | |||
RIP...
Stave my friend, you have your hand on your old fella yet again. : I have a little Beemer 328i, which is a 2.8L six pack, the engine characteristics aren't even close to the 4L Ford. The 2.8 is as smooth at 6500rpm as it is at 2000rpm, it's like a turbine in how smooth it is. The way the power builds is also different, it just continues to accelerate harder and harder as revs build, at no point does it taper off. It just begs to be revved harder. Now my DEV5 XH was revvy for a 4L Ford, however it was on another planet compared to the Beemer. My XH had a AU bottom end, with new bearings, and it was balanced, yet at 5800rpm it still felt like it wanted to explode compared to the Beemer. The 4L are hirribly undersquare, that is, much longer stroke than the bore, which simply doesn't encourage high revs. The rod angle ratios are terrible, which increases side loading on the pistons. With a standard and tired bottom end like you have, I'm surprised you haven't lunched your engine already. At 7000rpm you may as well throw a hand grenade under the bonnet. Get the bottom end balanced, shot peen the rods, fit stronger rod bolts, better/lighter pistons, and fit new bearings, and you may have a chance.
. Oval Everywhere... |
16-08-2008, 07:40 AM | #17 | |||
Smile
BTW ..dont go into politics...
16-08-2008, 07:42 AM | #18 | ||
around the place
4.1cc nitro motor, around 40,000 rpm,
obviously it doesnt have a valvetrain to keep up with that kinda rpm... Stav, exactly what are you set out to acheive? If you want to wind rpm, its not all about the stroke... The valvetrain comes into account, cam, springs, and the valves themselves etc etc. Then you have the matter of flow, spark and all the other variables. You cant have an 11 sec car for $0
16-08-2008, 07:51 AM | #19 | |||||
RIP...
If it were a pure drag car/engine, in a cortina or similar, then the smaller capacity might make sense, as spinning to 8000rpm and making 400hp but making bugger all below 5000rpm is ok in that application. Reality is, you need to throw it on a dyno now and see where peak power is anyway. I suspect it's not over 6000rpm. In that case, it's pointless revving beyond 6300 anyway. Quote:
16-08-2008, 07:57 AM | #20 | |||
Smile
16-08-2008, 08:00 AM | #21 | |||
Smile
16-08-2008, 08:03 AM | #22 | ||
around the place
if you had the bottom end setup to withstand 7000 rpm, you would have to get a cam suited to that rpm range, and springs, and valves that are strong enough to withstand that amount of rpm with those harder springs. Which would also mean you have to do away with the hyd HLA and go solid. Then you would likely need to upgrade injectors to support the fuel at those rpm providing the bottom end infact does hold together. Once you've got past those few hurdles, then you would probably need to alter the serp belt setup, so its not boiling the power steering fluid, cavitating the water pump, and spinning the alt too hard. Then you will probably find a rod will kick out anyway. There is a lot that comes into play, and i doubt anyone has had a 4.0 which they could reliably, if at all wind up to 7000 rpm.
16-08-2008, 08:06 AM | #23 | ||
Smile
Well...I have found myself withno other questions after all these years Thanks for the input.I think I am nearly ready grass hopper
16-08-2008, 08:22 AM | #24 | |||
RIP...
16-08-2008, 09:26 AM | #25 | |||
Sly like a G6
This is why it's easy to pick up extra power in a BA/BF through a flash tune. Just keeping the cam advance (and overlap in a BF) steady from 5000 to 6000 keeps the power increasing up to redline.
16-08-2008, 12:27 PM | #26 | |||
Boost Addict
