Old 12-08-2008, 11:38 AM   #1
nastyapul
nastypaul
Default Mk2 escort work shop manuals
hello all, I have just purchased a 78 4 door esky for the purpose of auto crossing it and was wondering if any one knew where I could download a workshop/repair manual for one. I have found a few places claiming to have them, but they al seem to be for post 1980 escorts.
I guess this has already been covered, I just cant find where.
If any one could help, I would appreciate it.
cheers.
nastyapul is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2008, 12:44 PM   #2
Roy Rogers
1978 models are the same as 1980 (BC model). Mk2 are the same shape but a little different in badges, petrol tank location, front struts and only came out in 1300cc/1600cc Kent motors.
President
Small Ford Car Club of NSW
www.smallfordcarclubofnsw.com.au
Roy Rogers is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2008, 03:17 PM   #3
nastyapul
nastypaul
this cant be it?.... can it???
http://pdftown.com/Ford-Escort-Service-Manual.html
I only need it for the silly little stuff i.e. ATM i cant work out why the dissy spins freely and the screw that normally locates it just keeps turning.
cheers for the reply.
Old 13-08-2008, 01:32 PM   #4
Roy Rogers
No that's not it. In Australia we had Mk1, Mk2 and BC. In the UK and other countries they continued on with MK3 and so on. The BC was a Australian thing like the TD Cortina (model designation codes)
President
Old 13-08-2008, 02:02 PM   #5
nastyapul
nastypaul
cheers for the reply mate.
I will just have to bite the bullet and buy one of the gregorys type manuals I think (assuming they are still in print)
Old 14-08-2008, 11:42 AM   #6
T3man
T3man's Avatar
Just keep an eye on eBay - the genuine Ford manual is far better than Gregory's and they do come up from time to time.
The book you want is for MkII which ran from 1975-1980. (light yellow cover IIRC)
If the dissy is turning then the lock stud is either missing or the thread is stripped - you may have to remove the dissy and do a "heli-coil" repair to the hole. Check the thread on the stud first though as you may just be lucky that it is the item that is stripped.
Old 14-08-2008, 01:34 PM   #7
nastyapul
nastypaul
thanks for that....
will have a look, and a swear, and another look, maybe swear again. it is in a difficult possi to get good visual access to, but nothing a bit of looking and swearing shouldn't fix.
Old 15-08-2008, 03:51 PM   #8
boyracer
There is usually a bloke at the markets selling used manuals.
boyracer is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2008, 05:18 PM   #9
nastyapul
nastypaul
which market?
Old 21-08-2008, 03:05 PM   #10
nastyapul
nastypaul
getting mucked about with manual, but I will get there. quick question though, To remove the dissy on a 1.6 mk2, do you need to remove anything else (inlet manifold) and is it just the one 12-14mm bolt at the rear that needs to be removed.
never played with the engine bay of an escort, and rather than do something the hard way, I thought I'd ask.
cheers in advance.
Old 21-08-2008, 03:11 PM   #11
Sterling
just remove the adjusting bolt and it should slide out...?
make sure low tension lead disconected too.
Sterling is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2008, 03:37 PM   #12
nastyapul
nastypaul
all leads are off etc, but just cant seem to get a spanner onto the offending bolt. it would seem a few things need to be moved to allow access :
any tips?
cheers
Old 21-08-2008, 06:21 PM   #13
Sterling
well the adjusting bolt is never easy to reach, but once its out, it should jsut slide out?
you might have to have some serious patience tho... turning a bolt, 1/8 of a turn each time will take a while, but u no its worth it!
Old 22-08-2008, 08:46 AM   #14
nastyapul
nastypaul
dammit!!! was hoping there was a magical way of talking to it that will make it just pop out onto the floor. Bugger.
cheers for the reply people, very much appreciated.
Old 22-08-2008, 09:14 AM   #15
Sterling
speedy or "ratchety" spanners work best
