Old 11-08-2008, 09:55 PM   #1
TX3
Rally hard
Default KF2 4wd gearbox/transfer box trouble
I'm having a bit of trouble here people.Anyone got any advice about this particular prob.Thought I might of done a clutch the other day but it turns out it may be a touch worse.I have discovered that my kf2 4wd laser has a driveline prob.When you put it in gear it don't want to go and there is a grinding sound when you put it in reverse.Now I'm just wondering what thoughts are out there
as to what would be the prob.
cheers Rob
TX3 is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2008, 09:33 PM   #2
hako
hako's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Regularly gives valued, considered advice to others.
Sounds like the clutch is not disengaging - have you checked the adjustment?
hako is offline   Reply With Quote Multi-Quote with this Post
