06-08-2008, 02:51 PM | #1 | ||
MADED.6
well as some of u may know i got myself a 90mm maf which is actually 100mm so i need to make myself a new intake pipe.
this is how it is right now. i i want to make it flow better so i want to go from the top throttle body to the maf/airbox then come from the other throttle body to the pipe. now i either need a 90degree bend off the top throttle body to the aibox or 2 45degree bends. the only thing is using 4 inch piping its not gonna have alot of room. ur thought/comments will be muchly appreciated. cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
06-08-2008, 05:01 PM | #2 | ||
Boost Addict
Gawd i suck at the drawing
from what i understand you wanted a 4" collectpor at the MAF? well i would run two 3" pipes from the T/Bs and let them joing in a nice flowing collector just before the MAF (i know the pic is a little abrupt in its flow design). does that make sense?
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO Can't live with it, can't live without it! |
06-08-2008, 05:04 PM | #3 | ||
not here much anymore
well anything is going to be better than what youve got : looks like spaghetti
have you thought about changing manifolds?
2024 F150 XLT
06-08-2008, 05:32 PM | #4 | ||
MADED.6
so dont run 4 inch piping i was thinking that as i recon it might be to much air for it.
so u recon run 3 inch piping to the throttle bodies and into a 4 inch collector at the maf or just get a 3-4inch reducer and judt run full 3 inch piping? cheers josh.
06-08-2008, 05:51 PM | #5 | ||
MADED.6
i thought something like that but im going to make my own custom airbox.
06-08-2008, 06:07 PM | #6 | ||
they call me Tibbo
how close does the MAF have to be to the throttle bodies?
06-08-2008, 06:10 PM | #7 | ||
they call me Tibbo
ohhh and what is the inside diameter of the t/b's?
06-08-2008, 07:38 PM | #8 | |||
Boost Addict
yer thahat i sorta tried to draw lol ... i would where the two 3" pipes join expand it to 4" ... there is no such thing as too much air, however the TBs outer dianmeter appear to 3" so the individual runner to teh TB doesnt need to be larger than that.
06-08-2008, 09:07 PM | #9 | ||
MADED.6
the maf doesnt have to be close to the throttle bodies just in the normal spot and inside diameter is 65mm i think they are.
outside is 3inch. ahh yeah i get what u mean eveilchief ill have to get some 90degree 3 inch bends maybe a 45 and some straight 4 inch. what do u recon 2 90degrees or a 90 for the top and a 45 for the bottom? how would i get them to make it go from 3 inch to 4 inch? cheers josh.
06-08-2008, 09:30 PM | #10 | ||
Boost Addict
id probably see if u could get away with 2 45deg from both TB, let the top one run as far to the right hand side and the stright it up with anotehr 45deg to face straight forward, where as teh front TB run a 45 deg and let that pipe join at the same angle into trhe top runner.
the way i would join it to 4" is. get a piece of 4: pipe now to make two 3" pipes into single 4", i would cut one 3" pipe on 45deg angle so that 2" remain of that pip e... ah biugge rit ill draw it ...
06-08-2008, 09:53 PM | #11 | ||
Boost Addict
there we go .. thats how i make my collectors
06-08-2008, 10:29 PM | #12 | ||
MADED.6
ahh yeah now i get ya looks easy when explained properly lol.
so u recon 2 45degree bends on the top on and 1 on the bottom one? is that so it flows nicely? sorry im not so good with making intakes flow good this is the first one i have ever made. well ill order some bends and stuff and get into it on the w/e most likely. i need to make intake pipe and make a custom airbox before my tune on 28th of this month. cheers josh.
06-08-2008, 10:40 PM | #13 | ||
MADED.6
is this sort of what u mean i no its a dodgy pic but u get the idea.
06-08-2008, 10:49 PM | #14 | ||
Boost Addict
yer pretty much
btw use S/S for intake piping, mild can flake internally over time due to humidity. as for enclsure have a look at the BA XR/GT Pod filter setups ;) now thinking about it, the GTs use a 3" intake pipe, but u may be able to reuse the POD enclosure and host a 4" POD in it
07-08-2008, 06:46 PM | #15 | ||
MADED.6
i was going to use alloy for the piping or should i use steel?
so will it be much gain using 45degrees as its going to cost about $60 more but then again i do want it to be good? and yeah i have a pod style airbox but deicded to make a custom airbox so itll flow better or do the pod style box's flow pretty well? cheers josh.
07-08-2008, 07:07 PM | #16 | ||
Boost Addict
havent heard anything about the Pod style ones for that matter, but i guess a custom one will be cheaper by the end of teh day ... i was suggesting S/S as its easier to weld compared to alloy. you can use a 90deg bend just cut in half ... gives u two 45s ;)
07-08-2008, 07:18 PM | #17 | ||
MADED.6
ahh yes lol very smart man lol.
and nah i have a mate who can weld it so that'll be all good. do u have anywhere i could get s/s bends from? cheers josh.
07-08-2008, 10:35 PM | #18 | ||
Boost Addict
yer i use midway metals http://www.midwaymetals.com.au/ i pay between 22 to 25 bucks per bend for 304 polished bends and 15 bucks a mtere of polished 3"
08-08-2008, 06:06 PM | #19 | ||
MADED.6
ahh yeah sounds good is that like a trade price or just normal price.
cheers josh.
09-08-2008, 02:07 PM | #20 | ||
Boost Addict
fu*cks me; my price ... changes on who serves me
11-08-2008, 12:06 PM | #21 | ||
MADED.6
well rang midway metals all up its going to cost about $116 thats 2 90degree bends 1 mtr 3inch straight and 1 metre 4inch straight.
they only sell the pipe by the meter so thats why it is so expensive. thats not that bad the alloy was going to cost me about that and this way i have a mate who can weld it all for me instead of sending it to a mates mate. evilchief what do u think about mild steal coated in alum or something. i went to an exhaust joint and they said theyd do it but he doesnt want to make the collector he is trying to find one but he will be using mild steel coated in some alum spray or something like that? i think ill do it myself. cheers josh.
11-08-2008, 02:15 PM | #22 | |||
11-08-2008, 02:34 PM | #23 | ||
MADED.6
yeah it doesnt worry me to much about the left over.
cheers josh.
11-08-2008, 07:42 PM | #24 | |||
Boost Addict
nothing feels better than doing something urself ;)
11-08-2008, 09:09 PM | #25 | ||
MADED.6
true that man yeah im going to order the piping tomoroiw stuff it me and my brother are going to spend the w/e making my airbox then my intake pipe so should be good fun.
now someone buy my ba xr8 pod styale airbox lol. cheers josh.
19-08-2008, 06:21 PM | #26 | ||
MADED.6
well went to order the piping today as i was to busy last week and they have decided in the space of a wekk the dont do meter lengths they only do it in lengths of 6 meters.
so ive been ringing heaps of places today to find piping i found 1 place that will do 1 meter of 4 inch and 2 meters of 3 inch and the 2 90degree bends but for $165. ill ring a few other places tomorow and see how i go. cheers josh.
19-08-2008, 10:45 PM | #27 | ||
Boost Addict
id offer to query my sources, but postage would be a little bit of a killer
20-08-2008, 12:25 PM | #28 | ||
Its gone V
Try also exhaust shops.
20-08-2008, 07:33 PM | #29 | ||
MADED.6
nah got it all from another place my mate had some 3 inch straight so just got the 2 bends and some straight 4 inch.
cheers josh.
20-08-2008, 08:02 PM | #30 | ||
Hey mate just saw your car on you tube lol... Type in v8 windsor stroker twin throttle body, Nice stuff hey but from the video i can clearly see what ya need now.
