Old 28-07-2008, 05:03 PM   #1
b2tf
not here much anymore
b2tf's Avatar
Default Nokia 6110 Navigator, howto setup?
Guys
Ive got the above phone but the navigator never seems to want to work, do I have to do something specific to set it up? Im with Virgin if that helps
2024 F150 XLT
Old 28-07-2008, 05:54 PM   #2
Jason[98.EL]
Jason[98.EL]'s Avatar
i have the same phone
but i am not with virgin ( dont think that would be the prob )
in the 6110 it is a stand alone gps reason i went with it for some reason it does take a while to log onto the network i would give it a good 2-3 mins to find the satalites ect
mine depending on conditions can take a good 4-5 mins to log on
if it doesnt log on in that time you may have a faulty unit
hope that helps
jason
[SIGPIC][/SIGPIC]
Old 28-07-2008, 07:36 PM   #3
efI_Fairmont
efI_Fairmont's Avatar
G'day mate ive got one of these phones, and found a firmware update helped alot. It can make a difference sometimes, depending on the errors you are getting.
Here's the Nokia Link: http://www.nokia.com.au/A4612230
You can also update the Route66 software for these phones, I think you get a free update for the Australian maps too (can't remember the exact update I got free, I think it was Q42006 or something like that). You have to install the Route66 software from the CD that came with the phone, then update from there.
Hope that helps.
For Work: '95 EF Fairmont
For Play: '03 BA GT-P
efI_Fairmont is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2008, 07:44 PM   #4
efI_Fairmont
I also think by default these phones have what it called ActiveGPS, which downloads a list of satellite locations to aid with GPS locating (ie supposed to make it quicker etc). You could check to see if it is enabled, and if not enable it and see if it can connect to GPS. Without this enabled, it can take a couple of minutes to get a GPS fix.
To check if it's enabled or not, you go into the Navigator application, then Options > Settings > Extras > Network Connection. It does cost extra, however, because it is considered the same as a data download.
Old 28-07-2008, 07:50 PM   #5
The Yeti
The Yeti's Avatar
I'll try for an update on my n95 tommorrow as so far I think its a waste of space
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2008, 09:03 PM   #6
b2tf
b2tf's Avatar
Thanks guys, Ill have a look into it. I dont use it at all but it does bug me that there's stuff on there that doesnt work.
2024 F150 XLT
Old 29-07-2008, 08:23 AM   #7
DBourne
DBourne's Avatar
also b2tf, when you are first getting GPS signal, make sure you are either outside or close to a window.
flickr
DBourne is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2008, 12:00 PM   #8
Ladiesman217
I can count to potato!
Ladiesman217's Avatar
Also pays to note that like the n95 you must have slide the keypad out when using it for navigation as the the GPS receiver is under the 8 button.
AU III XR8 UTE
Ladiesman217 is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2008, 08:09 PM   #9
Macca23
Macca23's Avatar
I use the same phone and its excellent, Ive got red light cameras etc all loaded in as well
The delay is because the gps receiver in the phone takes a bit but once it grabs it, it works quick the next few times.
You can quicken it up buy turning on a feature that allows the phone to connect using the internet and it finds you in the matter of seconds im led to believe, but then it costs DATA on your plan which can cost alot depending on what data amounts you have on your plan.
As above update the firmware. And i find the maps not tooo bad, but will be looking for the update when its about. Its not the best fora pure street navigator, but is very handy still if you don't have one.
Macca23 is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2008, 09:33 AM   #10
scoupedy
I have the same phone on Virgin and no problem,
The GPS will take some time if you shut it down say on the Gold coast and then try to use it again in Brisbane the phone still thinks its on the Gold Coast, they find themselves quicker if they are turn off and on in similar places.
I would take it back to where you bought it.
good luck
scoupedy is offline   Reply With Quote Multi-Quote with this Post
