Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Blue Power Racing Developments
Blue Power Racing Developments The home of Blue Power. Website Link
Old 28-07-2008, 11:42 AM   #1
gp1
Default Difillipo Big Boy System
Hi Guys,
Do you guys sell the Difillipo Big Boy system? If you do, is it possible to replace my herrod cat-back with the DF cat-back. The car is an XT 3V.
I wanted to retain the herrod headers and cats if possible due to cost.
What would be the cost of the DF catback (Big Boy) version?
Any feedback would be greatly appreciated.
Gino
gp1 is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2008, 08:15 PM   #2
Craig
RIP Craig - 13/11/08
Craig's Avatar
Hi Gino,
Yes BPR are Di Filippo agents, there is no system available for an XT because of the rear bumper but if you ask nicely Di Filippo can bend the two rear pipes to come down so the rear bumper doesn't have to be cut.
The cat back is only available in stainless steel at $1800.00 + fitting or freight.
Cheers Craig
Craig is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2008, 09:38 AM   #3
JAYBA
Originally Posted by Craig
Hi Gino,
Cheers Craig
Do the diffilipo's come out the rear of the car on both sides, (does the exhaust go from 3.5inch over the diff back to twin 3'?
is the big boy system suitable to run with a kenne bell kit?
JAYBA is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2008, 09:54 AM   #4
Theo@BluePower
Bluepower
Theo@BluePower's Avatar
The Big Boy Diflippo comes out twin outlet on drivers side, however can be optioned to dual twin.
The difilippo exhaust is perfect for use with the BPR KenneBell kit.
Theo
Theo@BluePower is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2008, 10:26 AM   #5
gp1
Hi Craig,
Thanks for your reply.
Do you know if it's possible to fit the DF cat-back to my existing herrod headers and cats. The herrod headers are the series 2 pacemaker design? I find that the herrod system is a bit too quite.
Also, my rear bumper is already cut to accomodate the exhaust.
Gino
Old 30-07-2008, 07:02 PM   #6
Craig
Craig's Avatar
Originally Posted by gp1
Hi Craig,
Gino
Yes Gino the system will bolt straight up.
Cheers Craig
Old 05-08-2008, 12:44 PM   #7
xrman1986
I was wondering would you loose power if you only put the dual 3inch cat back system on standard cats and headers.. and if you only had the one muffler instead of to would that be way to loud for road use.. i think in north QLD we have like a 98 to 100 db limit..
xrman1986 is offline   Reply With Quote Multi-Quote with this Post
