Old 24-06-2008, 03:39 PM   #1
tickford90
Default Loose Brake Rotor
Hey guys,
Just a quick question to the mechanics out there. I have a AUII sedan forte and went to check my brake pads today and noticed that the rotor would move with my hands and felt like it wasn't on securely. I always thought the rotor was bolted on somehow but is this right? It doesn't move much but it is sort of worrying me? your opinion will be much appreciated!
P.S. Yes I do need new pads.
tickford90 is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2008, 04:03 PM   #2
Foggy
Dont worry about the movement as AUs have floating discs. The discs just sit on the wheel studs and centre and a pushed on tight by the wheel.
Foggy is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2008, 10:22 PM   #3
EvilChief
Boost Addict
all in order nothing to worry about it
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 26-06-2008, 08:48 AM   #4
tickford90
That's good enough for me!
Cheers guys!
Old 09-02-2024, 06:03 PM   #5
OldfartsBF08
OldfartsBF08's Avatar
Default Re: Loose Brake Rotor
Hi what about BF 2008? I jacked my car car up and could wiggle the wheel, so took wheel off to check wheel bearings but noticed that the disc was flopping around quite a bit?
Thanks
2008 BF XR6 MKII
MICHAEL Old Fart
OldfartsBF08 is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2024, 06:09 PM   #6
Mechan1k
Mechan1k's Avatar
Ford run floating calipers on all later models.
If you wheel was moving about when tightly bolted on ... I'd be more worried about wheel bearings or tie rods/ends.
Old 09-02-2024, 06:22 PM   #7
OldfartsBF08
Everything looked right except for the wheel and disc.
What about having after market rims, could this be an issue, not tightening enough??
2008 BF XR6 MKII
MICHAEL Old Fart
Old 09-02-2024, 06:26 PM   #8
Mechan1k
Mechan1k's Avatar
could be a number of factors ... the centre bore may be incorrect .. or not have the seating ring with the aftermarket rings ... and it may not be seated right on the hub itself.
Do you have a standard wheel to test it with??? To ensure the wheel mounts right (spare wheel will work)
Old 09-02-2024, 06:33 PM   #9
OldfartsBF08
Yeah I will have a look at it tomorrow,
Thanks
Thanks
2008 BF XR6 MKII
MICHAEL Old Fart
