19-06-2008, 08:37 PM | #1 | ||
Hi there
I recently had to replace my distributor on my 1993 manual Ford TX5. Unfortunately I had to use a refurbished one. Ever since then, it developed this annoying RPM problem. The REVS drops too quickly for smooth gear changing. I try to drive my car carefully, thus don’t change gears fast. But now with this new refurbished distributor, the REVS (RPM) drops too quickly for smooth gear change. Especially for 1st to 2nd then to 3rd. From 4th onwards, it’s fine. Before the distributor failed, I was able to change gears smoothly, even when doing it slowly. I’m not sure if the distributor has anything to do with it to be honest. Does anyone know how one can make the RPM needle drop slower so that I don’t get a jerky gear change please? Any help will be much appreciated. Thanks guys. |
21-06-2008, 10:29 AM | #2 | ||
Over Thinker
either the dissy or the efi engine computer may be at fault
undo the battery terminals to reset the computer if still no better a diagnostic may be required
My car goes Brumm Brumm |
23-06-2008, 08:50 PM | #3 | ||
Thanks 'dirty hands'.
How long do you think I have to keep the battery disconnected? After the distributor was replaced, I installed some seat covers to protect my leather seats. Since the driver has an electric seat, I did disconnect the battery. My gear change & the rev problem didn't go away. For how long should the battery be disconnected? Thank you for your advice so far. At least I can ask Ford now to test something, regarding my RPM problem. Enjoy your week. |
02-07-2008, 11:46 AM | #4 | ||
just diconnect the battery and put your foot on the brake peddal to drain any power that was left in the car for about a minute or 2....
02-07-2008, 06:58 PM | #5 | ||
Thanks 'laser_power'
That's an excellent idea : I'll try it when I get home tonight. Thanks again |
04-07-2008, 07:54 PM | #6 | ||
What happens when the air conditioner comes on? Does the idle drop or does it maintain speed or slightly increase speed. The reason I ask is the IAC may be faulty or poorly setup.
04-07-2008, 08:17 PM | #7 | ||
Hi coop1er
If I'm not mistaken, it's quite normal for a car to loose bit power when the AC goes on. Before I had the distributor replaced, I noticed it does look like the RPM needle drops a bit when the AC is on. Now with the refurbished distributor, it does exactly the same, but it definitely feels like it has lost more power for when the AC is on. With more power, I mean V6 engine power. But luckily the RPM needle doesn't drop too much that it causes the engine to stall. But it sure looks like the AC is drawing more power than it used to. Thank you for that question. What might be the fault in this scenario then? |
04-07-2008, 09:20 PM | #8 | ||
If the idle control valve isnt working then when the a/c comes on at idle, revs will drop. Also when you are changing gears and take your foot off the accelerator the ecu should open the idle control valve a bit to prevent the revs from dropping too low.
Did you set the timing correctly? It should be 10 degrees btdc at 650rpm with the ten &gnd terminals bridged in the little diagnostic box. |
