G'day people,
My question is for the drag racers out there. What wheel and tyre combo do you use when your at the track in your BA ute? Mine has the standard GT brakes (Mark II) which are blue front and rear. I was thinking drag radials on stock steel rims but I dont know what fits or what sizes are available. Thanks Travis
2004 BA MKII FPV Pursuit 6sp manual in Mandarin MMR Built short motor, all the good gear. Kenne Bell 2.6 intercooled kit from BPR Tuned by Xtreme Ford Tuning - 400rwkw Build thread here |
#2 | |||
Location: Working, chasing after my daughter and working
#3 | |||
#4 | |||
Thanks Travis
#5 | |||
From my experiances the best clutch for the strip is the Textralia Z grip, still has good street manners but can handle alot of punshiment at the strip, so yeh it would proberly be a good idea to upgrade the clutch before you head out. |
with the standard brakes you can fit a 16" wheel over them
#7 | |||
#8 | |||
I ran widened 16 on my when I was racing it and then Bren260 used the same rims and tyres but his was an XR8. If Brembo's are fitted it would be a different story
Are there different types of steel rims you can use for the ba or are the stock black falcon steelies the ones to use with M/T's. If there are different ones where can I get some in Perth. I can fit 16's on the back of my car being an XT.
Im getting a PD blower kit fitted on my 3v in a couple of weeks and will need the extra traction for the strip.
2003 Ba xt Falcon 3v 5.4l Engine: Eaton M122h supercharged 8psi, water to air intercooled, FRPP Hot Rod cams, 85lb/hr injectors, custom fuel rails, Shelby GT500 carbon fibre intake, maxed out factory 3v heads, fuel cell Drive shaft: Veems modified 1310 series components, 3" X 0.65" tube, solid cross universal joints and heavy duty centre bearing. Weight saving of 2.2kg and an increase in critical speed of 2,000RPM. Gearbox: Fully rebuilt BTR 4sp, Chryogenicaly treated, high stall 490rwhp E85 |
#10 | |||
#11 | |||
I've got 18" wheels on it ATM and there looks to be a good 1 1/2" to 2" clearance on the internal diameter of the rim, but maybe the depth might be an issue. I will see if I can find someone with a stock ba steelie spare that I could borrow and test fit. If that works ill buy a pair and get them widened to 8" Cheers Travis
#12 | ||
Try looking around for some cheap ba alloys, be a bit lighter than steelies. Wish i kept 2 of my old ones
![]() With the brakes, would they be the same as the PBR upgrade ones (the red ones)? If so 16" will fit on the back but not on the front |
where can you get the steelies widened. Does any tyre place do it. Wouldnt the stock 16inch steelies be lighter than 16inch alloy wheels. I know alloy is lighter than steel but there is more of it in wheel.
#14 | |||
KenneBell Australia
Less than 22psi may help with a launch but will eat up HP bigtime down the bitumen. 275 is a bit big and hungry on the HP too. Buzz me from the track if u need "on the spot" advice - 0438 351 351 Chris
Bluepower Racing Developments Proud Australian Distributors of Kenne Bell superchargers The Quickest, The Fastest, The Baddest Boss Blower of all. www.bluepower.com.au |
#15 | |||
#16 | |||
#17 | ||
The Anti XLR8V8
How do cars fit 15" Welds? Like below...
![]() Does anyone know what brakes fit under welds or convo pros? |
