Old 16-05-2008, 05:34 PM   #1
RepSpec
Formerly XG-Panelvanman
Default A bit of sika should fix it...
hey all thought id share these pictures i took today at work of a motor on a boat that came through our shop. we are re powering it...cant imagine why tho :hihi:
cheers
brendan
My Ride:
BA MK2 Wagon, dedicated LPG, white.
modifications:
cargo barriers, tow bar
RepSpec is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2008, 05:41 PM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
looks just like Kevs Last diff, not his boat by any chance :
Originally Posted by Riksta
Old 16-05-2008, 06:33 PM   #3
gz1
gz1's Avatar
I guess they are trying to disable some of the cylinders for better cruise economy, like the new hondas and jeeps.
gz1 is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2008, 06:50 PM   #4
Yaw
Ford Fanatic
Yaw's Avatar
Years ago in Formula 1,this reminds me of several Ferrari retirements which were described as "electrical problems". Mechanics would give the lie to this saying things like "yes, it was an electrical problem. A conrod went through the block and knocked the distributor off!"
Everyone is entitled to my Opinion
2007 Territory TX SY RWD Ego
Yaw is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2008, 06:52 PM   #5
richa
handsomest man in showbiz
richa's Avatar
If you ask me,it's just as well the oil line wasn't knocked off the bottle,Iv'e heard those 2strokes don't like that.(all sorts of bad things can happen)
What kind of rat bastard psychotic would play that song right now...at this moment?.............
R.I.P. Dr Thompson...
'72 GS
richa is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2008, 06:53 PM   #6
LUXO_8
windsor user
^^^ Could have also been a fuel problem......piston knocked the carby off
Old 16-05-2008, 07:09 PM   #7
Thornie
Off smelting
Thornie's Avatar
lol that holes only a little bit bigger than the one my father in law blew in the side of his lawn mower, holes in blocks are always in pressive though.
Thornie is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2008, 08:42 PM   #8
Ringo
I see you....
Ringo's Avatar
Wasn't this exact explanation given by George Fury back in the turbo bluebird days when the L18 engine went bang ....?
Ringo is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2008, 08:49 PM   #9
Gammaboy
Grinder+Welder = Race car
Gammaboy's Avatar
I thought it was Bartlett or Moffat?
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear"
- Too much power is never enough....Mark Donohue on the Can Am Porsche 917.
Gammaboy is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2008, 11:24 PM   #10
Tote
Tote's Avatar
Similar to a Yamaha 175 outboard one of my mates had many years ago, wouldn't start due to the conrod lodged in the starter motor.
New bottom end under warranty, $11,000 in 1990 money
Regards,
Tote
Go Home, Your Igloo is on Fire....
Tote is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2008, 06:46 AM   #11
xbcool
dazed&confused
xbcool's Avatar
a couple of bottles of chemiweld should fix it
ban frangipanis
beauty is only skin deep.
ugly goes all the way to the bone.
xbcool is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2008, 02:15 PM   #12
X000BOSS
I12 GO FASTER
X000BOSS's Avatar
hi guys. this thread reminded of some advice i needed. im guessing that theres a good chance that the motor went kaboom due to lack of oil. now, being new to the boat scene, ive just recently purchased a boat with an outboard which has oil injection. my brother suggested i dont use this auto oiling system. instead i should premix fuel and just run that. his reasoning was that in case the oil feeders or similar get blocked or fail, my engine will still be lubed.
ps. panelvanman im not trying to hijack ur thread, i just think you might be one to answer my queries. cheers.
MY WIFE IS SO IMMATURE, SHE SUNK MY TOY BOATS WHILE I WAS HAVING A BUBBLE BATH
X000BOSS is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2008, 06:59 PM   #13
RepSpec
it all depends on the motor and the system been used with it.
the motor should have an oil warning alarm that will tell you when oil is not pumping or is low...
OMC engines (johnson and evinrude) 2 stroke engines have what is called a VRO oil/fuel pump. it has been given a nickname in the industry as a Very Rearly Operates pump, because it fails often. if you have one of these engines, get it looked at and see if it is working.
the oil systems are there to serve a purpose and they do actually vary the amount of oil that is delivered to the engine, it can vary from 50:1 and below to 100:1. if you run at 50:1 the engine will be smokier than it is now
hope that helps mate
cheers
brendan
My Ride:
modifications:
Old 18-05-2008, 11:47 AM   #14
cool65
carefactor zero
cool65's Avatar
I reckon some should post it on the ls1 forum for the new ls3 prototype
cylinder deactivation which is what holden is going for on their V8s
cool65 is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2008, 11:55 AM   #15
Paxton
Cobblers!
Paxton's Avatar
My Yamaha (130 V4) hasn't had any problem with oiling, however my mate with the same engine and boat had his engine seize because of lack of oil. He premixes his fuel now.
The best thing about Oil Injection is a lack of Oil Smoke, as the engine is always properly oiled presuming the OI System works.
My next boat is going to be a 4 Stroke if only so I don't have to worry about Oil.
Ego BFII Ghia
Titanium Silver E53 X5 4.4i
Gunmetal EF XR6. Now retired from active duty.
Roses are red. Violets are blue. OS X rocks. Homage to you.
Paxton is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2008, 12:49 PM   #16
X000BOSS
I12 GO FASTER
X000BOSS's Avatar
thanks for the help brendan + paxton. might disable the system and premix my own fuel. ive been reading about failing oil pumps all over the place. i think ill live with a little extra smoke. cheers
