Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Blue Power Racing Developments
Blue Power Racing Developments The home of Blue Power. Website Link
Old 14-03-2008, 01:27 AM   #1
danz
Default turbo installtion and custom tune
hey guys i was recommended to use as the best for tuning. I recently purchased a full turbo setup off an xr6t. I have the turbo with internal waste gate, intercooler with piping, manifold, dump pipe, 2bar map sensor, boost controller and all the water and oil feed and return lines. I already have a 2.5 inch exhaust and full lcd and ss inductions.
My question is what price am i looking at for the installtion of my turbo kit and how much for the custom tune. I already have a flash tuner. I want my car to run on stock fuel management and make around the 230rwkw mark around 6-7psi max.
Can all this be done in a day?
Thanks, Daniel
danz is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2008, 08:11 AM   #2
Bluepower
KenneBell Australia
Bluepower's Avatar
Thanks, Daniel
Hi Daniel,
this all looks pretty reasonable - I would need around 2-3 days on a job like this - its not meaning a 3 day labour cost, however these things are never a straight "bolt off, bolt on" deal.
230rwkw on a 6-7psi deal with an intake and ex is quite reasonable, hopefully valvesprings will be up to task. generally if you bring the boost in gently even on fairly worn springs your power request is usually quite achieveable safely.
We are in the middle of building a new premises, so for a chat or booking, pls drop me a line and we can work something out.
Chris
Bluepower Racing Developments
Proud Australian Distributors of Kenne Bell superchargers
The Quickest, The Fastest, The Baddest Boss Blower of all.
www.bluepower.com.au
Bluepower is offline   Reply With Quote Multi-Quote with this Post
