Old 13-03-2008, 08:27 PM   #1
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Default WOW.. Ford '2.4 V8' powered Clubman?
The article mentions an awesome weapon if ever I saw one. Holden made something like this, don't know if they still do.
But what caugt my eye was the last line:
There's more to come: Caterham says the RS Performance badge will sit alongside its established - and soon to be expanded - Ford-powered Seven range.
Caterham catapult
Old 13-03-2008, 08:34 PM   #2
Powdered Toast Man
Professional Mouse Jockey
Powdered Toast Man's Avatar
You mean the Elfin range? Elfin are an Australian company and power their cars with the 5.7/6.0L Holden (Chev) V8s.
How do Caterham get 300kw from a 2.4L engine, no matter how many cylinders it's got? It must rev to 15000rpm or something and be almost as cranky as a formula 1 for daily duties. I'll be interested in seeing some road tests, I'm sure they will pop up on Top Gear.
Isuzu MUX for towing horses - currently no Fords in the stable
Time flies like an arrow; fruit flies like a banana. Groucho Marx
Powdered Toast Man is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2008, 08:39 PM   #3
Yellow_Festiva
Where to next??
Yup, thats them. I remember they were powered by the 5.7's... and around 100 grand.
2.4 litre V8 lol... I can see the marketing spin now "Power of an 8 from the capacity of a 4"...
Old 13-03-2008, 08:48 PM   #4
Powdered Toast Man
Elfin are still going. They were at the Melbourne Motor Show with a couple of Chev V8 powered cars.
I was about to edit my post when my connection dropped out lol; but I was going to rewrite it to say how do they get 300kw from a 2.4L and still have it reliable with nice road manners. I mean F1 are powerful but I wouldnt want to use one of their engines everyday. But then I guess you wouldnt want to drive a Caterham everyday lol. More of a track day car.
Old 16-03-2008, 05:11 PM   #5
Bossxr8
Peter Car
Bossxr8's Avatar
The V8 isn't a Ford engine. I've got a suspiscion thats it an engine out of an A1GP car, 2.4 litres, very light weight and revs to 10,000rpm. Who else has an engine of that capacity?
Some models of Caterham have 2.3 litre Ford Duratec 4 cylinders.
Old 20-03-2008, 06:13 PM   #6
Rev28K
re
Location: Victoria - where being slow & incompetent is considered being "safe"
This is surprising to me.
Caterham got a mileage recently with a show car turbo version of the Cosworth 2.3 four with veiled hints of a production version.
There was a 2600cc (?) V8 based on two Hayabusa top ends on a custom V8 block that was put in one of their wide body frames two or more years ago. I think that could be taken out to 3000cc with custom work. Small physical size, nice heads, high output and a bit more tractable than a bike engine.
The A1GP V8’s (and other engines that are used in similar series – e.g. Caparo) have a fair bit left in them. They are run in one make series where they aren’t chasing the absolute last rev or every absolute packaging or weight advantage like say F1 engines. Having said that I don’t imagine they would be that cheap either.
Scuderia Rev: Otto the tow pig - 2007 3.0 litre Coupé, vernünftig schnelle aber kein peilstab, Bathurst 2007 und 2010 zwölf Stunde Gewinner Jaffa the angry ant - mid 70's Honda 市民の, 73 と立方インチ LSD Elle "the body" shell - early 70's Datsun フェアレディ coupe. いい体は彼女の内側、内側と土台を待つ
Rev28K is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2008, 10:13 PM   #7
Hally
Tom Walkinshaw recently bought Elfin. Not 100% sure of the details. From memory Mike Simcoe (guy who designed the Monaro) designed the Elfin Streamliner as well as the more 'naked' version for Elfin a few years ago. He also owns one.
Hally is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2008, 11:31 PM   #8
Gammaboy
Grinder+Welder = Race car
Gammaboy's Avatar
I'd suspect its a Powertec or Brammo V8 (Brammo makes 400hp at 10,000rpm, but its 2.8l, see specs here, Powertec powers the Radical SR8 that lapped the nurburgring in 6:55 and makes 360hp from 2.6l), It could even be the engine from the first version of the Caparo T1 (the 2.4 that made 470hp has been upped to 3.5l and 550hp in the T1 now)?
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear"
- Too much power is never enough....Mark Donohue on the Can Am Porsche 917.
Gammaboy is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2008, 11:49 PM   #9
The G6ET Spot
How long before it goes belly up then.Are you sure he owns it, could be Skaife or the Kelly's. Who really knows!
The G6ET Spot is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2008, 11:50 PM   #10
ebxr8240
Performance moderator
ebxr8240's Avatar
I'm fairly sure that engine has R1 Yamaha heads and billet crankcase ???
If so that would be why the rpm and power output !!!
Daily driver GTE FG..
