Old 01-03-2008, 03:51 PM   #1
GTP 330KW
Blueprint GTP
GTP 330KW's Avatar
Default Cleaning engine
I'm interested to know how everyone else cleans their engine and engine bay. Do you use a dry rag or pressure cleaner or something else? What's the best thing to do?
2003 Blueprint BA GTP. Full Herrod stainless quad exhaust, Herrod Helix spacer, Herrod lowered suspension, Unichip, Big Mouth Cold Air Induction, BMC air filter, Tripod X Force guages, leather seats, premium sound, sunroof, Satellite navigation and reversing sensors.
GTP 330KW is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2008, 03:57 PM   #2
Windsor220
Now Fordless
Windsor220's Avatar
Pressure clean the engines at work. Seems to be the best way to clean them especially when very dirty\oily. Extra bits can be touched up with armourall or something similar afterwards.
Old 01-03-2008, 04:03 PM   #3
Creampuff
149 rwkw of Style
Creampuff's Avatar
just a rag and armourall. I would never let it get dirty enough for anything else!
Creampuff is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2008, 11:40 PM   #4
Geez Louise
Awesome
Geez Louise's Avatar
Location: In my own little world..Everyone here knows me :)
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: All the behind the scenes things that help the community.
Put it in the dishwasher! A bit of Finish Powerball does wonders!!
Geez Louise is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2008, 11:42 PM   #5
fpr_esp
351 xe s pac
fpr_esp's Avatar
bahahaha
if it aint a ford dont drive it
fpr_esp is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2008, 02:43 AM   #6
ea90gl
ea90gl's Avatar
I always use a pressure sprayer, its worked great on all the cars Ive used it on and it doesnt cause problems if you be aware of things like air filters (mor for the older cars), alternators and ignition coils etc etc. Always good to degrease while the engines dead cold otherwise it will dry up real quick and then your back to square one, as soon as its all soaked in degreaser turn the car on and start spraying. Also once your done keep the car on with the bonnet down so most of the water can evaporate real quick
ea90gl is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2008, 08:33 AM   #7
nj351
Ultra White
nj351's Avatar
A gerni is the only way to clean an engine just cover your main electrics what car are you cleaning some have different problems when cleaning eg:coilpacks on commonwhores.
Also use a non costic degreaser as it leaves white powder on some metals.
MID NORTH COAST FORD OWNERS CLUB MEMBER NUMBER 351
nj351 is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2008, 11:10 AM   #8
GTP 330KW
Blueprint GTP
GTP 330KW's Avatar
Thanks for your responses everyone. nj351, it's a BA GTP.
Old 02-03-2008, 01:06 PM   #9
EASYBOSS
Matakana NZ
EASYBOSS's Avatar
Ha ha, close to what I actually do, dishwashing liquid actually works quite well, a very string mix in hot water, all over the engine and bay and hosed off, a cheap solution done at home.
SOLD : BA XR8 4 Speed Auto in Mercury Silver, Bluepower CIA, Full Diffilipo Big Boy Quad System, Tune, 4.11 Diff Gears, FPV Starter Button, FPV GT Rear Spoiler, Tripod Gauges, PWR Trans Cooler. 230 RWKW's. Many thanks to Chris at Bluepower Racing Developments
Hers : F6X build #150 in Ego, Stock as a Rock, untill the warranty runs out, including the extended one.
My Work Wagon AU Futura Wagon in Gold.
On the Farm : Ford 6600 Tractor
EASYBOSS is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2008, 09:32 PM   #10
AUXRVIII
I use Meguiars quick detailer and a rag, if it's going to clean the outside well it sure will do the engine bay. Also it won't turn anything alloy white, dry out the hoses or cause rust on anything.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2008, 11:46 PM   #11
EvilChief
Boost Addict
CT14 & CT18 .. soak - hose off ... done
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 03-03-2008, 01:22 AM   #12
goldfire
when I got my AU, i gave it about 6 hours of overall attention on the first day.
Engine detailing, was pretty stock standard i guess, some over the counter de-greaser followed by a fresh boiled water rinse and some elbow grease.
Then a high pressure cold water spray, little bit of a dry rag and some armourall to make it sexy.
looked good for me but all is in the eye of the beholder.
btw.. go and get yourself a steam cleaner thingy.. mine personally came with several attatchments and my god they can be used for anything, can really help clean a engine bay or even bad tile grout!.
Last edited by goldfire; 03-03-2008 at 01:24 AM. Reason: again more basic spelling and grammer
goldfire is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2008, 09:19 AM   #13
WOTDAH
Yes YOU
WOTDAH's Avatar
I swear by this stuff also great for exterior. I spray my car down with diluted CT18 let it dry for a couple of hours then was my car as normal. It get those dam bug off.
Although no trees were harmed during the creation of this post, a large number of electrons were greatly inconvenienced.
WOTDAH is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2008, 10:14 AM   #14
Dezza
Parts bin special
Dezza's Avatar
try own an EA ;) . It's stays clean for all of about a day.
I use the pressure washer and degreaser. I just cover up the distributor, and go nuts!
Old 03-03-2008, 05:58 PM   #15
JamesR
oh i know the feeling..
1977 MkII Escort Ghia.
2006 MY07 Subaru Liberty GT Spec B wagon.
my photo blog;
http://www.jamesruff.net
JamesR is offline   Reply With Quote Multi-Quote with this Post
