Old 25-11-2007, 11:30 AM   #1
la2or
Your Hero
Default What's QLD law regarding your odometer not working?
Is there any laws that say the car is unroadworthy.
IN particular Im interested in that I have sibling learner drivers how I would record their driving times on this particular car since you are meant to record the speedo or odemeter.
Sorry i dont know the correct term for it whatever the thing that says you've trave 121,345 km so far a cumulative figure.
la2or is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2007, 12:18 PM   #2
Eu-GenixX
Eu-GenixX's Avatar
what car is it? get it fixed... no point taking leaner drivers in it if you can't record their mileage.......
the only laws i know about odometers.. are you are not allowed to wind them back.... but it's ok to change clusters even if it has lower km's travelled....
Eu-GenixX is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2007, 02:55 PM   #3
Wardo
Wardo's Avatar
I know you have to have a working odometer for a safety cert as I just got one, not sure why though. Can someone enlighten me?
'03 BA Futura, 18' -235/40, Kingsprings superlows, Monroe GT Sport, 2.5" Cat and exhaust, K & N, Typhoon CAI, RDA Slotted & Extreme pads.
302 Cleveland being rebuilt, Ebay said 351 liars!!!!! Home found! '01 AU II. Bring on the smoke
Wardo is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2007, 03:30 PM   #4
jaydee
jaydee's Avatar
If a car is fitted with something from the factory then it has to work, and a speedo is in this category.
How is the learner going to know how fast they're going too?, and if you do your test in it I doubt they'll even consider it if the speedo doesn't work.
If it's an older type car check the cable hasn't worked its way out at both ends.
jaydee351
4DV8
jaydee is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2007, 03:47 PM   #5
RIPGMH
RIPGMH's Avatar
I think the issue is with the odometer not the speedometer.
RIPGMH is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2007, 10:23 AM   #6
Casablanca
carburettor
Casablanca's Avatar
yea its weird now with RWC's as Eu-Gennixx has said you can change the cluster but cant wind back sounds stupid but it has to be there to record how many k's youve done pretty much for servicing
Originally Posted by irlewy86
HSV GTSR..... $125,000
HSV Team shirt..... $65
Tank of Fuel....$75
Being cornered by a 17 year old bogan with 2 kids and no teeth telling you how much she loves HSV's..... Priceless
Casablanca is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2007, 10:21 PM   #7
Blast2
Default odometer not work
Hi, think you will have to get odometer fixed or replaced. As you are teaching sibiling to drive, which makes you liable and you know of fault. Plus don't they have to keep log of time and kph travelled. To repaire it there is Able Instruments and Max Instruments.You may lose points and cop a fine if police decide to check car.Currentley there is a lot of exschoolies going for licences in Brissie.
Blast2 is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2007, 10:55 PM   #8
juve_fan14
One reason could be to teach them to drive. Persons driving ability to drive isn't measured by how many hour they spent behind the wheel, if you think the person is ready to get his/her P's that's when you should take them to do the test not when your odometer says they travelled certain amount of distance!
juve_fan14 is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2007, 09:52 PM   #9
ford_chick
The laws all changed around learners licences in June this year and now they need to prove they have driven a certain amount of hours before they can go for their test.
You will probably have to get it fixed in this case. We have an XE and XF ute and neither of these work. I think they were a bit of a dodgy design in that era.
ford_chick is offline   Reply With Quote Multi-Quote with this Post
