Old 10-11-2007, 06:42 PM   #1
1992laser
Default Probs with rear brake pad change
Hi Guys
while trying to change the rear brakes on a 1992 Laser i am unable to depress the brake cylinder all the way in. Therefore there is not enough room to fit over the disk (basically the brakes cannot open wide enough).
So is there any trick to depressing the brake cylinder? I have tried forcing it with a g-clamp but no luck. Any help will be appreciated
Cheers,
Grant
1992laser is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2007, 06:57 PM   #2
smally289
growing up is optional
smally289's Avatar
Pretty sure there is a bolt on the back of the caliper that you have to remove. Under the bolt you will find a hex inside the caliper that will accept an allen key. Turning this will retract the piston.
Dont use a G clamp!!! There is a handbrake mechanism in there.
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2007, 01:06 AM   #3
crankyTX5
Agree with the above, had the same deal with the Telstar, I believe repco sell the tool with their brake pads. Allen key worked fine, be careful nt to strip the thread and don't use the g clamp.
crankyTX5 is offline   Reply With Quote Multi-Quote with this Post
