Old 17-10-2007, 10:40 PM   #1
GreenMachine39
Default price advice
I went to pedders suspension today and got a safety check done on my car they quoted me a shitload of money i want to know if there overcharging etc ,
here is what they found was wrong
Front
Shocks - working unevenly - $310
Ball joints - lower ball joints worn - $130
Upper bushes - worn - $215
New cam cas kit - $245
Lower bushes - worn - $215
stearing gear - New power steering rack , Leaking - $440
Brake rotors lipped - $170
Rear
Upper bushes - worn - $100
lower bushes - worn - $120
Lateral arms - Watts linkage bushes worn - $65
For all this i was quoted a total of 2810 dollars , 940 of that being labour , should i look elsewhere or is that about normal
GreenMachine39 is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2007, 10:45 PM   #2
pauljh74
pauljh74's Avatar
I'd get it checked elsewhere. It has been stated by others dealing with Pedders in the past that they have been told shocks need replacement when they were only fitted elsewhere a couple of weeks prior. Basically, the "free" checks are a way to bring in new business by telling customers they need work done on things that don't need work done.
Originally Posted by Mark Webber
Not bad for a #2 driver
Mark Webber after winning the 2010 British Grand Prix.
pauljh74 is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2007, 10:47 PM   #3
GreenMachine39
Only 2 things im positive about is the power steering rack and the watts linkage
Old 18-10-2007, 05:54 PM   #4
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Get a 2nd / 3rd opinion. I'm sure Pedders will find problems with a new car.....
A friend had the same sorta quote. Was after a similar inspection / report. They quoted $3000 worth of work on a $3000 car...
They called him a week later after he said "too much" to reduce the labour price by $450.....
Old 18-10-2007, 07:53 PM   #5
XR Martin
XR Martin's Avatar
Bit hard to know if it an overpriced quote if you dont tell us what vehicle it is and how many kms are on it
2004 BA wagon RTV project.
Old 18-10-2007, 08:22 PM   #6
Yaw
Ford Fanatic
Yaw's Avatar
Mate, take the car to Fulcrum suspension. I can tell you they are THE SUSPENSION specialists, I know most insuance companies use them when suspension work is needed and they are also a site sponsor.
Everyone is entitled to my Opinion
2007 Territory TX SY RWD Ego
Yaw is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2007, 08:32 PM   #7
351EL
Have a look where he is there is no fulcrum place in Rocky.try Dobinsons.
351EL is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2007, 01:19 AM   #8
[Tonko]
What's green is gold
[Tonko]'s Avatar
Pedders suck,
One that was recommended to me is a mechanic aswell, tried to charge me $280 to replace the coil in an EL2....
Gave me a run down of prices which included, Booking fee - $20 Raise car on hoist - $20, Spark plugs - $50 (for 6!) Electronic tune up - $90
And after all that, the timing was out, they had the car for 2 weeks and put 120k's on it....
Im going back to the old guy i always used to, he does it for cash and is a great bloke...
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU -
1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps-
[Tonko] is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2007, 12:51 PM   #9
GreenMachine39
au series 2 sr with 118k on the clock
