Old 09-07-2007, 07:31 PM   #1
Dayvo
Default thermo fan AAAAGGGGGGGHHHHHHHHH
Hi all
Still having trouble with the thermo fan not comming on in the ol" KF laser
I have changed the fuse and the relay but still no go. The fan works ok if you connect it to the battery but won't come on when the car is running or idling .
If i disconnect the thermo switch on the thermostat and ground the wire onto the engine block the relay clicks but fan still doesn't work .
Anyone have any ideas as how to fix it before i take to it with a baseball bat
cheers. Dayvo
Dayvo is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2007, 08:40 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
well relpace the wires between the sensor and fan including the push on connectors solder if possible
wires must be broken or corroded
if still no good add a internal switch and rewire direct to the battery
so you can watch the temp guage
problem solved :
My car goes Brumm Brumm
