Old 27-06-2007, 07:22 PM   #1
T3rminator
T3rminator's Avatar
Default EPA noise test procedure
Hey guys. Had a mate who was dobbed in for an EPA test. Took his car to get the test done a couple of days ago. Whilst holding the car at the index test RPM it registered 89db which is fine (has to be under 90db). But when the tester backed the car off to idle it registered 94db. He now has 28 days to get it compliant.
Does this procedure sound right? I thought you take the db at the index RPM?
Rides (past and present)
Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual
Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m)
AFF motto - If contrary views trigger, please use ignore button.
T3rminator is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 07:27 PM   #2
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
crannersEL got done and went the EPA procedure
You may want to take a look at this thread:-
EPA Test
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
