Old 26-06-2007, 02:18 AM   #1
SLO-04L
It Never Ends
SLO-04L's Avatar
Default Rear Demister
i have a 96 Ef GLI and having problems with the rear demister, the fuse is fine but when i push the button nothing happens, is there supposed to be a light behind the button or a light on the dash or something, even replaced the button is there some common fault for these that i should be looking for?
SLO-04L is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2007, 09:33 PM   #2
hamka
check the rear window and see if the plugs are plugged into the points on the rear windshield sometime they fall out.
hamka is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2007, 11:51 PM   #3
SLO-04L
It Never Ends
SLO-04L's Avatar
yeah checked that, its all good, might just get an auto elec to look at it
Old 27-06-2007, 11:13 AM   #4
frd_crzer
:D:D
frd_crzer's Avatar
could just be the switch mate change the switch
Cheers Grant
frd_crzer is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 01:36 PM   #5
SLO-04L
It Never Ends
SLO-04L's Avatar
yeah mate went to wreckers and got new switch nothing changed... is there ment to be some sort of indication that its on? light on the dash or in the switch or something?
Old 27-06-2007, 02:08 PM   #6
BaYa
Just Cruzing
BaYa's Avatar
might be your lines on the rear window are broken check that, and test the power on the switch end and the window end may not be getting the power other wise ya got me.
Dark Blue 96 EL XR6
MOD'S
Herrod Extractors & Redback exhaust
lowered
Au xr6 rims
Successful Trades with:BradensEBxr6, snypereb, EDXR6T, ORSMF6
_______________________
BaYa is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 07:04 PM   #7
yahoo189
yahoo189's Avatar
yeah, i thought that the yellow lamp was supposed to light up when the demister comes on.
Hamish
ED, Lowered Lovell Springs, Monroe GT gas shocks, SAAS Racing Buckets, SS Lab Sound System, Carbon Fibre Wheel, Full Sports Exhaust System.
yahoo189 is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 07:20 PM   #8
SLO-04L
It Never Ends
SLO-04L's Avatar
is that in the dash or in the switch?
Old 27-06-2007, 08:24 PM   #9
Tanksenda
Tanksenda's Avatar
There should be a light on the dash that lights up. When you turn on the demister, you should hear a relay click in the fuse box. If you cant hear that it could be the relay. Check for voltage at the switch as well.
Tanksenda is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2007, 02:33 AM   #10
SLO-04L
It Never Ends
SLO-04L's Avatar
thanks mate thats what was confusing me i just had no indication if anything was on,will check the relay tomorrow
Old 25-02-2012, 11:54 AM   #11
toothless
toothless's Avatar
Default Re: Rear Demister
i know its a old thread but i have the same problem excepte my econ light comes on
phat ltd in the making very lowly
toothless is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2012, 01:54 PM   #12
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
it sounds like your demister switch is plugged into the wrong plug?
sometimes the plugs get swapped around behind the demister switch, there is usually a spare plug there, clipped to the back of the switch surround.
this is for bench seat models for the economy/normal mode for the trans.
they dont run a console so have nowhere else to put the switch.
the dash looms suit a few different models/options.
and the worst thing too with the demister not working is you cant program new remotes for your car.
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2012, 09:06 PM   #13
toothless
toothless's Avatar
i swaped it around and i can hear the realy clicking but no light comes up on the dash
Old 24-03-2012, 09:39 PM   #14
my67xr
my67xr's Avatar
sounds like you have a blown globe,
is the demister working now?
67 XR Fairmont
Old 24-03-2012, 10:03 PM   #15
toothless
toothless's Avatar
not sure if it does yet i will wait for either winter or when it rains
