12-06-2007, 02:33 PM | #1 | ||
I read today that the XR4 goes on sale today with a "tweaked" version of the focus motor delivering greater power and torque than the standard focus motor.
Quote from the article: The 2.0-litre Duratec four-cylinder, borrowed from the garden variety Focus, has been tweaked to produce 110kw of power, up a meagre 3kW on the Focus engine, but with a much flatter and broader torque profile. The XR4's peak 190Nm is reached at 4500rpm, but with 80 per cent on tap at 1500rpm and 90 per cent available from 2200rpm through to 6150rpm, the flexibility of the engine is impressive. Full article found here: http://carsguide.news.com.au/story/0...-21822,00.html So .... Does anyone know if there is any physical mods to the stnd motor or is this just a retune? If its just a retune how easy would it be to have it done to my Focus Zetec and would ford do it for me under warranty ???? |
12-06-2007, 02:50 PM | #2 | ||
Virtuous Bogan (TM)
Pretty good question.
SO I assume most would be in the ECU, other than that I have NFI.
12-06-2007, 02:56 PM | #3 | ||
Non-Regular Member
It has a different exhaust system and different intake.
If you retuned a standard Focus motor you could get more than 3kw and 5nm gain. |
12-06-2007, 03:00 PM | #4 | ||
I recon its all in the revised exhaust.
Rhubarb, check out the 2 engine mods in my signature, they all owe me nothing but lazy Sunday afternoons and I recon give me more than 3kw. http://fordforums.com.au/showthread.php?t=101280 http://fordforums.com.au/showpost.ph...1&postcount=26 (ignore the battery part) Welcome to the forums, make a intro thread. |
12-06-2007, 03:31 PM | #5 | ||
Thanks Black LS - interesting mods.
Does anyone know what the torque spread of the stnd motor is, and how this varies with fuel octane? |
12-06-2007, 04:40 PM | #6 | ||
fordxr5turbo.com
You can be confident that Ford Dealers won't provide support on tuning up to XR4 spec... it'd dilute the point of having the XR4 around.
12-06-2007, 04:40 PM | #7 | |||
12-06-2007, 06:14 PM | #8 | ||
2006 Focus LX Hatch
They'd be using the same gearbox I'd imagine?
12-06-2007, 06:20 PM | #9 | ||
I know it's been covered before, but isnt Fiesta ST/XR4's engine is from Ford Mondeo? And is it essentially the same engine that's in the LS Focus now?
12-06-2007, 06:58 PM | #10 | ||
Zoom Zoom
Correct Ives. LS Focus engine with intake and exhaust changes. It feels like a totally different engine and sounds unbelievably better than the vacuum cleaner in the LS.
XR4 uses a standard Fiesta gearbox with shorter gearstick for a shorter "throw".
2012 Mazda3 MPS
12-06-2007, 07:27 PM | #11 | |||
AFF Post NAZI
"Its not always about power, The car has to handle Beautifully" |
12-06-2007, 09:10 PM | #12 | ||
And Fiesta weighs 200 Kg less - that's 2 fat ladies and their shopping so XR4 should go almost ok...
12-06-2007, 11:34 PM | #13 | |||
Here is some more info...
MK |
13-06-2007, 03:04 AM | #14 | ||
Have a look on the Taiwan Ford website. They have the new updated Focus on there and if you manage to get to the specs page you will see that their updated 2.0 Focus is 110kw/190Nm.
Hope Ford Australia sell the Ghia with black leather and chrome interior trim rather then the ugly wood look. |
13-06-2007, 10:48 AM | #15 | ||
Getting to the specs page is not that easy for those that don't speak Taiwanese ... namely me.
13-06-2007, 09:15 PM | #16 | |||
Here you go: Focus Specs 148hp/19.4kg-m = 11k0kw/190Nm |
14-06-2007, 09:46 AM | #17 | ||
good work !!!
It will be interesting to see what gets released here in September. |
15-06-2007, 03:43 PM | #18 | ||
Wouldnt make me wanna trade in my Zetec however.
15-06-2007, 04:43 PM | #19 | |||
That was my dilemma. Should I take a Zetec now or wait for the new model with safety features available. In the end I got an 07 Zetec for $25200 driveaway whereas the new model would have been over $30k. |
15-06-2007, 04:49 PM | #20 | ||
AFF Post NAZI
not bad...
15-06-2007, 10:43 PM | #21 | ||
Good call, if you have say a Vectra now and wanna decent car then the XR4 would be on a short list for sure.
But seing I have an 06 Zetec the XR would not be anywhere near enuf to make me want to change. We just need some private tuners to come up with locally supplied solutions because theres a whole lotta Kw lurking in that Duratec. I reckon another 20Kw would transform the focus. |
16-06-2007, 05:26 AM | #22 | ||
But the same 20kw can added to the XR4! Imagine how much better that would go!
17-06-2007, 10:24 PM | #23 | ||
Hmmm for one of those I would sacrifice some space and rear doors. Ok ok I want one. Soon as I finish killing the wifes vectra...
17-06-2007, 10:36 PM | #24 | |||
The autos have 4 preset speed limiters. Redline in 1st, redline in 2nd etc etc.... |
17-06-2007, 10:39 PM | #25 | ||
Bseries Moderator
If your half serious about performance youll do the air intake and exhaust anyway and youll get a shitload more than 3kw or whatever it was. surely with an intake, header, cat and full exhaust along with a standard tune you would get another 20kw from a 2.0 duratec? what power are the blokes overseas making?
Long Live the Rugerspeed Primer Destroyer! Only those that attempt the absurd achieve the impossible. Serviced and maintained by Mascot Auto Repairs
18-06-2007, 07:14 AM | #26 | ||
I was under the impression the XR4 had revised gearbox gearing? As in shorter to make it feel a lot quicker than the standard Fez.
Anyone to confirm? All in all... it comes down to seat of the pants fun. Changing the gearing is an easy way to do that. |
18-06-2007, 08:55 AM | #27 | ||
the specs are all available on ford.com.au
18-06-2007, 09:12 AM | #28 | |||
LPG > You
LPG Lovers Association President & Member #1. : |
18-06-2007, 10:46 PM | #29 | ||
Does the XR4 still have 4 x 108 rims that will fit an LR Focus?
18-06-2007, 11:43 PM | #30 | |||
LPG > You
