31-08-2005, 12:26 PM | #121 | ||
X-Series Club Moderator
I don't think there is anything further to point out in the area of tank safety, the reality is the majority of tanks, regardless of what fuel they are designed for, will be rarely exposed to conditions which will lead to a dangerous situation. The safety measures in place seem adequate and there is always potential for human error.
Sourbastard, there are Monkeys in all professions, that expose the customer to different dangers in varying degrees. Unfortuanetly that is human nature, and Johnydep's attached article makes that point. Well put post though Sourbastard, very objective. Maybe a LPG racing category could be created so than the greenies would have a motorsport to support in preference to others due to the lower emmisions produced :
PROJECT - '77 XC Falcon 351C - Click Here DAILY - '05 Ford Territory BIKE - '12 Suzuki GS 500 |
31-08-2005, 01:05 PM | #122 | ||
Formally knowen as EBus
i'd like to go lpg for the cost's but not to lose power doing it, my mechanic told me if i do convert i would notice the power loss and with my car being gutless as it is i don't want to lose anymore power.
Car: :evilking: 91 EB Fairmont 3.9L :evilking: Changes: 5 spd manual Extractors, 2.5in exhaust AMG Quake 17's w/ maxxis rubba Lovelle superlows Cheap a55 Pod Filter Bike: CR250R 05 :evil3: |
31-08-2005, 01:49 PM | #123 | |||
Petro-sexual
31-08-2005, 01:52 PM | #124 | ||
Petro-sexual
Johnydep:
In that letter it says the nissan patrol had 2 tanks but only one was affected.... did the other one explode due to the first exploding? |
31-08-2005, 02:17 PM | #125 | |||
Read this; http://www.lpgaustralia.com.au/assoc...05final1%2Epdf It mentions; "as the investigation outcomes indicate the autogas tank may have been overfilled, and the pressure relief valve may not have operated to protect the tank, causing it to fail." This indicates either faulty workmanship and/or passing th buck. As all recent LPG systems are fitted eith a Automatic Fill Limiter, they should not be able to fill tank more than 80%, unless incorrectly adjusted. Please do not ask me anymore questions, ask these people http://www.lpgaustralia.com.au/index2.cfm |
31-08-2005, 02:22 PM | #126 | |||
And also keep in mind if after impact in a car accident, the LPG cylinder is hit with sufficient force to dismount it, that flamethrower will cease to become a flamethrower and will become a projectile.
1965 XP Falcon Deluxe Sedan 1978 XC Falcon Wagon Rallypack 2003 BA Fairlane G220 Windsor Powah!!! http://www.youtube.com/watch?v=m7hT9dxD2hM |
31-08-2005, 02:52 PM | #127 | |||
Back in Blue!
Not quite true, a couple of pages back someone mentioned an event called a BLEVE. This can occur if a tank is exposed to fire for a long period of time. Initially the pressure valve will allow gas to escape and some of the liquid in the tank will boil off as the gas pressure drops. This has a cooling effect on the cylinder, if the level of liquid in the tank gets low enough that the cooling effect as it boils off is not enough to reduce the temperature of the tank, an explosion may occur. This is not the best explanation, if you really wanna know the exact physics then I suggest you look it up, but it is possible for a tank with a fully functional relief valve to explode. This does take a long time to happen though and even knowing that it is possible I still drive an LPG vehicle. why? because if it is has been hot enough in the car for long enough to cause a bleve, then I am either no longer in the vehicle or I am dead.
Previous Ride 1: XE wagon 4.1 on LPG - RIP Previous Ride 2: VN Berlina wagon 5.0 EFI Current Ride : EF XR6 wagon (Manual!) Back in Blue baby! |
31-08-2005, 02:56 PM | #128 | |||
Back in Blue!
31-08-2005, 02:57 PM | #129 | |||
31-08-2005, 02:59 PM | #130 | ||
LPG > You
In an impact hard enough to damage or dislodge the LPG cylinder... chances are you won't be very alive anyway...
LPG Lovers Association President & Member #1. : |
31-08-2005, 03:02 PM | #131 | ||
heres my 2cents worth
i have seen 3 cars catch fire from petrol related faults(all were carby types)(one burnt to the ground) if they were on gas this particular fault would not have happened, needle and seat prob and fuel line i can say i've owned gas cars for 10 years and at the moment if it wasnt for gas i could not afford to run a falcon, i'd have to buy a corrola and fit a1.6motor and 5 speed(not that theres anything wrong with that)(might do it anyway and fit gas also) to me the less people who jump on the gas is cheap bandwagon and covert to gas the better, as with the rule of supply and demand gas should remain relatively cheap by comparison look at the options and facts and make the decision yourself |
31-08-2005, 03:02 PM | #132 | |||
Stuff it... Can we see a demonstration with the Pintara???? :hihi:
31-08-2005, 03:04 PM | #133 | |||
Back in Blue!
31-08-2005, 03:07 PM | #134 | |||
31-08-2005, 03:23 PM | #135 | |||
Back in Blue!
31-08-2005, 03:34 PM | #136 | |||
31-08-2005, 03:46 PM | #137 | |||
Back in Blue!
31-08-2005, 04:25 PM | #138 | |||
This part of the thread was not an argument of what has occured, rather it was looking at the potential hazards of petrol tanks vs LPG cylinders. As a potential hazard any pressurized vehicle has more destructive power in the event of a catastrophic failure then a petrol tank, simply because of what each contains, and how they are stored. Its point was also to highlight the concept that an LPG cylinder cannot explode is incorrect. Wether by design fault, lack of maintainence or simple chance, its does absolutely have the potential to explode and has done so on documented occasions as Johnny Dep posted.
31-08-2005, 08:04 PM | #139 | |||
Petro-sexual
From http://www.legco.gov.hk/yr97-98/engl...ry/967rp05.pdf - pages 9 and 10.
Faults in manufacturing happen all the time, some with more potential for serious injury than others, but they still happen. I watched a program just recently where a heap of people were having major pain after having a hip repacement due to the fact some mineral oil was left on the surface of the cup, that is insterted into the pelvis, from the machining process. You can never entirely avoid the possiblility of a failure, but the best way to reduce the risks with LPG is to use a licenced fitter and make sure your system is maintained correctly. Simple really, if you watch your own back you will have a lot less to worry about. Everything that has been laid out against LPG so far (with exception of the faulty pressure valves) has all been to do with human factors. So why point the finger at LPG? |
31-08-2005, 08:08 PM | #140 | ||
they call me Tibbo
I signed off this debate ages ago, it turned into a two way war about the safety of the tanks.. That lost me folks :(
31-08-2005, 08:38 PM | #141 | ||
Petro-sexual
Nothing really to do with the topic, but interesting none the less, I was just doing a bit of searching and came across this homegrown aussie invention to eliminate BLEVE's.....
http://www.scienceinpublic.com/fresh...colinyoung.htm I hope it works |
31-08-2005, 08:41 PM | #142 | |||
31-08-2005, 08:52 PM | #143 | ||
Well, given this thread is called "Whats your Views" and some have shown a clear case that the explosive nature of a stored gas is a major concern... I think the "safety" aspect of the view has been clearly covered. Yes, all fuels have a POTENTIAL to combust and LPG, as a gas, has a very low flash point, I think its been covered enough.
Personally, safety of LPG is a small issue in my mind but not the major one. Personally, I think the lack of power compared to petrol and its dry fuel compound killing engines not set up for it correctly is more of an issue to me. $2500 for an LPGas set up is great... better add at least another $1000 if you want your engine to last the distance though.
31-08-2005, 09:57 PM | #144 | ||
Availability is also an issue,not every servo has it and if traveling away you need to plan your trip though it is getting better.You need a specialist mechanic also,not as easy to find. The explosion issue is nowdays not worth thinking about as it is almost non exixtant,when was the last time anyone heard of it happening even in an accident,but there is still a perception. Cars nowdays are far more capable of accepting it but very few conversions would cost $1000. More like $2000-2500,this being even more if there is finance involved thus increasing the length for a return. Average km per year is 20000 so there are lots of cars doing less. Threr are more involved reasons for some hipo cars v normal road cars but to average Joe in the street any small inconveniance is hard to overcome from the norm. The gas/oil companies obviously dont care otherwise more education/advertising would be used to entice people away from petrol.
igodabigblackshinycar and I relented and allowed a BMW into the garage. Last edited by deesun; 31-08-2005 at 10:03 PM. |
01-09-2005, 08:39 AM | #145 | ||||
Redhead extraordinaire...
Also the lack of power issue... it's not a major difference. It isn't as bad as all those who haven't driven any or many LPG cars make out. My EA is toeier on petrol but you feel a little thrown around, whereas LPG may not be quite as quick to respond to the foot-down but it is a much smoother ride. And you get to a stage in your life where you start driving like a grandpa anyway lol. As the Maddestman said to me yesterday, he enjoys driving off the lights like a grandpa and watching the hoons waste all that fuel, then meet up with them at the next red light. To be honest, I am not sure exactly what it does to the internals of an engine. I know years ago the issues were with non-alloy heads, and needing to get hardened valve seats and heads specifically designed to cope with LPG. Can someone please explain the exact process between LPG and petrol inside an engine, and why LPG apparently "wrecks" it? Also I think the benefits to the environment through cleaner emissions plus the fuel savings outweigh the costs of another engine over time due to apparent LPG problems. And what about cars that are designed with LPG in mind?
Bindi 88 EA- his car 88 Rolla - MY car Quote:
01-09-2005, 09:09 AM | #146 | ||
After getting my Javelin back on LPG again I've come to the conclusion that in old carb'd cars I personally prefer LPG. When its working properly, provides smooth power delivery and on old V8s gives them fuel running costs equal to modern cars (ie. LPG cost 1/3 as much, but they still use three times as much of it as my EFI V8). An added benefit is that although LPG smells, the car appears to run much cleaner and doesn't smell anywhere near as bad as on petrol .. (unburnt fuel). I also persoanlly prefer the sound of the engine running on LPG. When running on petrol the engine note is deeper, but not as nice and smooth as on LPG.
My Javelin has been running on LPG for 10years without the engine being opened up. Supposedly this is the very high nickel content in AMC blocks/heads which means they ran on ULP in the seventies/eighties without valve seat inserts .. i.e. head material so hard they didn't need it??. Anyway, it still sounds/runs fine and I think the valves/seats are holding up fine. The only problems I've had are the LPG system gunking up from poor maintenance (Doh!) BTW: Can someone explain what the problems are with valves/seats on ULP engines running LPG? I'd have thought nothing 'cos of the hardened seats? Is this correct?? |
01-09-2005, 11:22 AM | #147 | |||
Back in Blue!
01-09-2005, 11:29 AM | #148 | |||
LPG > You
01-09-2005, 11:35 AM | #149 | |||
01-09-2005, 11:39 AM | #150 | |||
Back in Blue!
