Ford POWER!
I was after some instructions on how to flush my break fluid. I found a pretty good doco on the PBR website http://www.pbrperformance.com.au/doc...System_000.pdf
and wondered if there was any other steps/pointers that people could point out? Do any other steps need to be taken because of the ABS? Thanks
Liquid Silver Ford Falcon AUII XR6 HP Manual ![]() Last edited by sickxr; 08-09-2006 at 10:15 AM. |
All Bran = Regular Member
If you're on Bris northside there is a crew at Lawnton that have a special on brake fluid flush/replace @ $20.
I thought I'd bookmarked them but I can't find it. I'm about to get busy but I'll have a search later and get back to you. |
#3 | |||
Ford POWER!
Found some topics on Fordmods, they say that its no different having ABS.
Liquid Silver Ford Falcon AUII XR6 HP Manual ![]() |
#4 | |||
For future ref the name of the company is Aussie Automotive Services. They have a website with a "specials" section but I'm damned if I can find it. Good luck with it... it can be a messy job. |
#5 | |||
Ripping it up
Wo are they? and do they use quality fluid or el cheapo? |
#6 | |||
As above, they are Aussie Automotive Services at Lawnton. My guess would be that they use a brake fluid that meets the appropriate standard for my vehicle. So far, so good... the brakes still work ;) I got the info off their website. It used to be aussieautomotiveservices.com which now goes nowhere. However, aussieautomotiveservices.com.au goes to a work in progress page. I guess you could always call them and ask if the special is still available. |
Ford POWER!
Well i did it, peice of cake!
