Old 07-09-2006, 06:13 PM   #1
ssouthcoast
Question AU 2 Manual on LPG
Hi All can any one help me decide weather to convert my au 11 6 clinder xl manual Ute to duel fuel . i all ready have a Auto AU Fairmont Ghia on lpg and have not had any problems but the Gas manuafatoir has said there is a possability of back fire with the manual when the engine is under load( eg in third gear insted of second ) . Has any one had any problems or know of others that have had these sot of problems ??????? :
ssouthcoast is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2006, 07:11 PM   #2
kenz
BOSS Pilot
kenz's Avatar
my au2 ute is a factory lpg and i havent had any troubles like that when its under load but a aftermarket conversion may be different i wouldnt know
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2006, 09:22 PM   #3
Smoked
Burnin Rubber
Smoked's Avatar
Are you swapping ECU? What gas system do you have, VSI or Mixer?
Perhaps if you post in the LPG forum, somebody might know.
2001 AUII Forte (LPG)
K&N Air Filter
Tickford Air Intake
***Coming Soon: Clear Side Repeaters***
Originally Posted by The-ShowStoPPa
...dont get me wrong this 3.8v6 is pretty special, it does come with the popular shake rattle and roll option and the auto compliments this with the ever popular snap crackle and pop feature
Smoked is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2006, 09:42 PM   #4
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
If your running gas , you should really have the metal pcv valve and the spring type airbox lid clips, then if you get a backfire you shouldn't run into any problems . cheers.
:eclipsee_
Old 08-09-2006, 09:42 AM   #5
ssouthcoast
Thanks i will do that ! some times you don't see the obvious .
