Old 03-09-2006, 11:40 PM   #1
Crash Lander
Default Minor body damage.
Can things like car door dings and small single point dents be repaired effectively, or do you get those bulet hole sticker thingos and just put one on every ding! :disco:
Some people think I suffer from A.D.D., but they... Oh LOOK! A Chicken!
Crash Lander is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2006, 11:43 PM   #2
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
Pretty much anyhting is repairable , depending on the sharpness and depth on the ding/dint its also sometimes possible to like remove the doortrim and push the dint back out by hand , then polish away the marks on the paint .
:eclipsee_
XR6-VCT-2000 is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2006, 11:47 PM   #3
Crash Lander
I got one quite nasty one on the rear door. Just under the window, where the shin flares out to the crease, There's a vertical dent that goes from the window to just under the crease. Looks like a vertical crease going over the horizontal crease. Might try and push a couple out from the inside though as you suggested. Can't possibly make them look any worse I guess.
Old 03-09-2006, 11:59 PM   #4
XR6-VCT-2000
Fantastic Plastic
ouch , a vertical sharp dint/dent over a horizontal bodyline creaseline might be a hard 1 to push out , usually small dings on flat surfaces push out sometimes , but a dint on a body creasline is usually hard to fully push it out , do it carefully though and as you said it couldn't look any worse than it does now/ you might get a majority of it out , but in the long run i think a ding on a factory bodyline/creaseline would have to be repaired to fully remove it .
If its a tough dint/ding / to tough to push out by hand / u can get something like an metal dolly or engineers hammer ( hammer with the round end on 1 end , not the nail puller ) , remove the hammer handle , hold the hammer head in your hand , then use medium force on the inside of the panel running/rubbing the rounded edge of the hammer over the dint while pushing on it firmly , dont go hitting the panel with the hammer , u'll dint it even more ! .... if you trust yourself you can try the above , thats if it is an agressive dint . Take your time though and do it gradually bit by bit pushing it out , rush it and u will crack the paint ! ...gl , cheers
:eclipsee_
Old 04-09-2006, 01:22 AM   #5
Smoked
Burnin Rubber
Smoked's Avatar
I take it a 4WD hit you when they opened their door?
2001 AUII Forte (LPG)
K&N Air Filter
Tickford Air Intake
***Coming Soon: Clear Side Repeaters***
Originally Posted by The-ShowStoPPa
...dont get me wrong this 3.8v6 is pretty special, it does come with the popular shake rattle and roll option and the auto compliments this with the ever popular snap crackle and pop feature
Smoked is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2006, 08:36 AM   #6
Crash Lander
No idea. Only had the car since last Monday. The dints were already there.
