drubie
1998 EL Fairmont.
Is there a common / easy fix when your climate control display gets very, very dim? Can barely see the numbers and only when it is very dark. All the buttons seem to be working OK. I see them on Ebay for around $200 - fair price? cheers, dave.
1998 EL Fairmont, 1975 Alfa Spider Veloce, 1982 Alfasud Ti, 1982 Jeep Cherokee V8 |
Oops, I slipped....
Or you could change the light globe in it ;)
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
I6 LICKS
just change the globe mate, might aswel put some blue LED's in there instead.
[ON DUBS]
you didnt dim it by accident did you?
the dash light adjuster also dims the climate control display. well, thats an assumption, does in my ED!
BA MK2 XR6T |
#5 | |||
drubie
cheers, dave.
#6 | |||
drubie
#7 | |||
The globe is always on and it dims when the headlights are on. I'd gladly sell you mine for $200 on an exchange basis ![]()
EF Falcon Sedan 5.0 auto with IRS "the man that crashs AFF" |
#8 | |||
OzEcruisers PRESIDENT
![]() Join Date: Mar 2005
I was lazy and got my fate to fix mine - in out in 20 minutes and thats with having a drink or two
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
Sick Puppy
So all it is when the display is totally blank but everything else is working ok is a blown globe? I didnt realise a LCD display would have a globe in it!
Yep thats right - just a globe. If the globe has blown you can still see whats on the LCD Screen its just very hard to see - look closely
Heheheh. LCD's don't illuminate themselves, they need some form of back-light so you can see the contrast between active and dormant segments. Old-school use a simple light bulb or LED, but these days they use fancy electro-luminecense panels behind the whole display for crystal clear clarity (no pun intended)
