21-08-2006, 10:37 PM | #1 | ||
Does anyone know if a CA18 or SR20 engine can be legally engineered into a MK1 Escort in Qld? I understand it would cost a fortune, but I'm curious as to whether or not it can be legally done.
22-08-2006, 09:30 AM | #2 | ||
Might seem obvious but, why don't you contact the Qld RTA? I know QLD has problems with interstate registered V8 Capris so maybe its a flat out NO. One phone call could save you a lot of money and grief.....either that or move to a more progressive state. :
22-08-2006, 11:42 AM | #3 | ||
We have a corolla sprinter with high power ca18 in queensland legaly registered. The secret is the "blue" plate. See the aforementioned rta. then look up an engineer and he will sort out a plan with you.
22-08-2006, 01:31 PM | #4 | ||
Frantic Ford Fanatic
Sacrilege !!!!!!!!! put a cosworth in it or a lotus motor, not jap stuff
BA SR Pearl Blue, 18" Alloys, Headers and 99% of the option boxes ticked |
22-08-2006, 01:41 PM | #5 | ||
Eskys with SR20s have been done before. It would be fairly easy for engineering, compared to putting in a 6 or 8 into it.
Get the motor out of an early S13, compared to a S15, from what I've been told, you only have to conform to the S13 year model's ADR laws. Although a CA18 would be cheaper to source. |
22-08-2006, 02:22 PM | #6 | ||
noooooooooo, please not :, My Esky was my first real car, you'll destroy my image of blowing off V8's in my worked mark II
22-08-2006, 02:34 PM | #7 | ||
White Lightning
get over it mate. the jap engines crap on anything we ever got. as long as its pushing a blue oval what does it matter.
22-08-2006, 02:35 PM | #8 | ||
GRRRR.....
I know of 1 being built now, should be registered in about 3 months
Now - 2007Renault Megane sedan, Steel Gray, 19" Koya Ambush with 235/35R19 Yokohama ADVAN V103, Eibach Pro-Kit. Gone but not forgotton - Diamond White 2004 LX Fiesta If you sneeze with your eyes open, do your eyes pop out??
22-08-2006, 09:27 PM | #9 | ||
Hiding in wheel smoke
should be able as they are 2 litre, same capacity as a pinto and the aspiration doesn't matter, but insurance will get ya ;)
22-08-2006, 09:36 PM | #10 | ||
Not a real big performance mod, but, what about this....
I had a Twin Cam back in the early 70s and in 93 my wife was looking a buying a Capri (new Convertable). I poped the bonnet and what did I see...an engine that looked very familiar..If a mazda 1600 DOHC is not a copy of a Lotus I don't know what is! Even better there is an 1800 version of it. The only problem I could see would be engine mounts (not to hard) and Distributor (could be an issue). Any thoughts??? |
22-08-2006, 11:23 PM | #11 | ||
Yeah, we just bought a 94 model Mazda 626 SDX last week. The test drive sold me! 2.5L DOHC EFI V6 engine. They seem prettey smooth..
23-08-2006, 12:54 AM | #12 | ||
Yeah, but they don't look like the original Twin Cam lotus motor. The 1600s do.
23-08-2006, 09:06 PM | #13 | ||
whats wrong with a ford V4 apart from how hard to find they are
23-08-2006, 10:09 PM | #14 | ||
They weigh about two ton and the power to weight ratio is probabley the worst of any engine ever designed and manufactured.
They are hard to find because most were in Transit vans which were either torched in frustration or converted to Falcon 250 6's that used less fuel and went about 450% better. I believe you will find a stash of them at Bobbin Head in Sydney where they were exclusively used as boat anchors. |
23-08-2006, 10:13 PM | #15 | ||
I's just saying that the Mazda engines are quite nice performers. The twin cam Lotus lookalike would certainly be the right choice..
23-08-2006, 11:14 PM | #16 | ||
Specialy considering it appears in a ford Capri and Laser.
hey also agree these mazda motors, specially over 2ltrs go like hell! |
24-08-2006, 01:42 PM | #17 | |||
24-08-2006, 04:39 PM | #18 | ||
I seriously doubt the power to weight ratio being the same a 2Ltr. Back in the 70s I can't remember a single V4 being used in any conversion around the traps or in any publications. The 1600, Twim Cam and 2Ltr where all the rage, (and very occasionally the 250cuin for track). I remember Bob Holden building a 2ltr with a BW automatic for Ford Australia to trial around 74 I think.
Maybe retro if your a POM |
24-08-2006, 08:49 PM | #19 | ||
1700 V4 2000 V4 2000E/GT
Engine 4 cyl ohv 4 cyl ohv 4 cyl ohv Capacity 1664cc 1996cc 1996cc Bore 93.67 mm 93.67 mm 93.67 mm Stroke 60.35 mm 72.42 mm 72.42 mm Compression ratio 7.7 or 9.1:1 7.7 or 8.9:1 8.9:1 Max BHP (HC) 76.5 @ 4750 rpm 88 @ 4750 rpm 97 @ 5000 Max torque lbs/ft 94 @ 3000 rpm 116.5 @ 2750 rpm 113.5 @ 3k Gearing 17.7 mph/1000 rpm 17.8 mph/1000 rpm Tyres 5.60 x 13 or 165 x 13 radial Kerb weight 2166 lb 2166 lb 2254 lb Length 14 ft 9 in 14 ft 9 in Width 5 ft 3.5 in 5 ft 3.5 in Top speed 84mph 84mph 98mph Average mpg 25 25 20 Pinto The Pinto engine was available in displacements of 1.3 L, 1.6 L, 1.8 L and 2.0 L. Due to emission requirements it was phased out towards the end of the 1980s. Applications: The 2.0 L (1993 cm³) EAO was used in many vehicles from the early 1970s. Bore was 90.8 mm (3.57 in) and stroke was 76.9 mm (3.03 in). The 1971 Pinto and Capri used this engine with a single Weber 32/36 DFAV carburetor and 8.2:1 compression. In this application, it produced 64 kW (86 hp) and 140 N·m (103 ft·lbf). The engine was produced in Cologne, Germany. Output in the Escort RS2000 was 82 kW (110 hp) and 161 N·m (119 ft·lbf). Applications: 1971 Ford Pinto 2000 1971 Ford Capri 2000 Ford Cortina Mk III and IV 1975 Ford Escort RS2000 1978 Ford Transit |
25-08-2006, 12:16 AM | #20 | ||
Schooled.. :
25-08-2006, 02:59 AM | #21 | ||
DPC PERFORMANCE Race prep
Escorts are to dear at $ 150 an hour id hate to drive one all day
: : i will excell with the knowledge i get on here : : FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria Ford Performance Car ClubFord Performance Car ClubFord Performance Car ClubFord Performance Car Club |
25-08-2006, 09:17 AM | #22 | |||
By the way your stats give the higher spec uk pinto...... Aus spec pinto. 93.8bhp 2lt/109lb torque. :Reverend: They don't call me pintopunter for nothing. Last edited by whooligan; 25-08-2006 at 09:33 AM. |
25-08-2006, 11:19 AM | #23 | ||
Cool
25-08-2006, 04:44 PM | #24 | ||
mk 1 capri
geez, i'v never seen a v4 ford in a car .seen plenty of them get rebuilt at hot rod shows .if you want people to look at something give them somthing they hav'nt seen.i think a v4 in a esky van done up write could have some WOW factor about it.then again an sr20 might give the driver a WOW factor.
25-08-2006, 08:01 PM | #25 | |||
tufLTD
My favourite quote: "Some people compare David Gilmour to God. He's great, talented & inspiring, but he sure as hell can't play the guitar like David". |
25-08-2006, 10:26 PM | #26 | |||
too many fords
26-08-2006, 02:19 AM | #27 | ||
broady081
dont go the rice burner go the rice pudding cooker COZZIE COZZIE COZZIE OI OI OI
26-08-2006, 02:20 AM | #28 | ||
broady081
if u want jap power id go a sr20
26-08-2006, 02:23 AM | #29 | |||
broady081
26-08-2006, 02:29 AM | #30 | |||
In the Forced 'lane
XE S-Pack 4 Runner XH11 Longreach |
