Hey all
My last post was about being told wrong information from my local Ford Dealer... And now ive been given alot of information and i am just trying to find out how much fact or fiction there is. So any info you can give would be great. Firstly: You can see my car by my signature below, and ive bought some 17" Rims. I want to get it lowered by 30mm. Someone (Im not quoting names to avoid issues) told me that if i do this it will scrape on everything, and i may have to take alot of driveways and speedhumps on an angle. The solution i was told is that i must have either 18"'s or 19"'s. Is this true ? Or will 17"'s be Ok ? how much truth is there in this ? ![]() Secondly: I was about to book in a exhaust upgrade for a full 2.5" Exhaust with High flow Cat and Extractors, but after listening to a V8 with exhaust it may be a little to loud. I was told there was a similar noise level between the two ? Is this really correct ? ![]() So then i was thinking of going extractors, high flow cat, and keeping my current 2 1/4" exhuast, and was told this would still give me the same power gains / throttle response / and fuel economy im after... Is this really true or would I be wasting my money doing this ??? ![]() Sorry to ramble on but i need these things cleared up b4 i go and spend my $$$$. Cheers Jeff
:eclipsee_ MY CAR :eclipsee_
#2 | ||||
![]() Join Date: Dec 2004
The only time the noise would be an issue is if you were running a very "straight through" system with absolutely minimum restrictions.. but thats unlikely from a standard off the shelf system. As for getting a 2 1/4" system.. dont bother, it wont make enough difference to make it worth the money.
SII XR8
Cant see anything wrong with lowering 30mm from futura height and having 17's.
Would basicly only drop you to xr height. Mines lowered 50mm front and 65mm rear from xr height and yes, at that you do have to work the angles. |
Sweet thanks man
Ive got a quote from Liverpool Exhuasts. How does this sound ? High Flow Cat 2 1/2" Exhaust Extractors (Hurricane brand) 2 dual straight through mufflers to reduce noise They quoted me $1000 Feedback Welcome !!!
i guess it depends on the type of exhaust, ie brand, whether it is mandrel or press bent, etc. i got a quote today for ph4499's, high flow cat and 2.5" mandrel bent for $1180 fitted, now mind you i live in alice springs, in the middle of australia, so to me that seems a bit rich given that you live in sydney
Yeah, I got a quote from RDP here in Brisbane for Pacemaker 4480's, magnaflow hi-flow cat, redback 2.5" exhaust with magnaflow muffler for just under $1000. That was before I mentioned I was a forum member too... Shop around a bit more I reckon.
#7 | |||
Formally Kia Chaser
![]() Join Date: Jan 2005
Casper is spot on (as usual) with the rims.
I got PH4499s fitted for around $500, and redback cats back for $350. You don't need a high flow cat for the I6 - just open up the front and rear entry/exits of the cat housing to 2.5" - usually another $50 to $100.
#9 | |||
Mr Polish
My forte was 65mm lower than standard and did scrape a little but still a decent ride and looked killer so 30 mm is not a problem
Detailology colour fx detail studio and R&D Lab SA's leader in auto detailing and paint treatments |
#11 | |||
Life's a Gas
Mine is XR height. I have to take about 1/3 of the speed bumps at an angle. My driveway at home is on a downhill slope, and I have to take it sideways and with caution to avoid scraping. I had superlows on my EL. Used to scrape everywhere. |
You must have huge speedhumps then.. I've got SL on the front and SSL on the rears (full tank leaves the tyres level with the guards) on 18" rims and I've never scraped a thing.
#13 | |||
#14 | ||
Sweet well its good to know that once again i have been mislead by a trusted, well known, Exhaust Center.
And to think that it was their mechanic that told me all this, and he owns a BA XR8. pfffft oh well. thanks all for your info. Ima stick with my 17" Rims, car lowered by 30mill and 2.5" Full Exhaust + Extractors.... i'll post a photo just to show off once my wheels are one... the before and after ![]()
#15 | ||
some of them will just try and sell you a high flow cat because they cant be bothered modifying the original one...i got quoted $115 to modify mine to 2.5" of $250 for a "high flow" 2.5" one. its just how they try to make money off people who dont know much/any better...not putting anyone down, but unless you know exactly what you want they'll try and sell you anything
#16 | |||
Next upgraded Mk1 Leopard
Uncle Ken
#17 | ||
Audi S3
hey you are in St Clair...
i like like 5 minutes from you then, ive probably seen you around before, maybe you me. ya never know!
#18 | |||
Mine doesn't stand out much just yet, but give her a few months ![]()
#19 | ||
i hear high flow cats are a load of **** anyways...I think there was test between standard and high flow and not much difference at all prolly better like every1 says just to modify larger diameter originals...On my EB xr6 i have lukey headers with 3inch collecter into standard but bashed out internal cat to 2 1/2 system with magnaflow muffler with a hot dog on the rear pipe...Dosent drone but still sounds beef...The thing u dont want is that drone at cruise,that i cant stand drivin heaps of commodores like that, gives me a head ache...I believe fitting a hotdog on the rear section prevents that or have 2,one in intermediate section then one at rear...
#20 | ||
well i got all the parts for my exhaust just recently off ebay, i also got a high flow cat just so i dont have to modify my original one, as well as that it was only $165 shipped to where i am anyway...$855 with shipping got my ph4499's, highflow cat and 2.5" redback exhaust...which i am going to fit myself as its easy enough to do
#21 | |||
My ute is an XLS (had XR suspension height from factory) ... and I have lowered it 40mm all-round now .... now I can get into pretty much all loading docks that I need to get in (ie: designed for trucks more than anything) ... the only time I have issues is when i am loaded up. But there are times that some places I do have troubles.
#22 | |||
Life's a Gas
The problem throughout the entire Canada Bay area (Five Dock, Concord, Drummoyne) isn't just the height of the speed humps, its the fact that many of them are very short lengthwise. The way I see it, a well designed speed hump is long enough to ensure that your back wheels are on top of the hump before your front wheels are back on the normal road level. Around here a lot of the bumps are very short, so that both your front and rear wheels are on the normal road level, either side of the hump which is ripping the crap out of the underside of your car. Maybe other council areas are just as bad. I do a lot of driving around Sydney though, and this council area seems to be about the worst. Driving a lowered car in Sydney probably presents more challenges than driving in other cities such as Melbourne and Perth for two other reasons: (a) Sydney's backroads are generally crap, with more potholes and other irregularities than is the norm elsewhere. I've lived and/or driven on the Gold Coast, and in Brisbane, Perth and Melbourne. I haven't found a place that has roads maintained as badly as Sydney. (b) Sydney's hilly topography means that you find a lot more dips and spoon drains running across intersections, ready to tear away at the leading edge of your car. So the upshot of this is that different rules for owning/driving a lowered car may apply in Sydney to elsewhere. |
#23 | ||
On the news the other night they mentioned that Sydney as the worst roads of anywhere in Australia ... not that surprising really ... cos I do a lot of metro driving ... and yeah ... it pretty crap just about everywhere.
I agree about the short speed humps that are very rounded as well ... and high in the middle too ... Eastwood in another area like that too.
#24 | ||
not so stock
I have just modded my XR within the past 2 weeks, pictures to come. I have put 17" mags with low profile tyres on, lowered the XR another 25mm and plonked on a 2 1/2" exhaust with a high flow cat. The exhaust, cat and twin chrome pipes set me back $550 fitted and it SOUNDS GREAT. When cruising and keeping the right foot under control there doesn't appear to be much difference in the noise, put the boot in and YUMMIE. I stipulated that the exhaust mods must remain under the legal dB limit..just check what it is where you live. My suggestion is go for it, you will not regret it. The only problem I find is that I now have the MOD BUG.
Liquid silver AUIII XR6, BA scuff plates with Tickford inserts, proudly displaying AU falcon.com stickers, lowered, K&N panel filter with wide mouth snorkle, 2 1/2 exhaust and hi flo cat, Illusion mags, slotted and drilled rotors. Next mods: extractors |
#25 | |||
#26 | |||
not so stock
I'm an old geezer (nearly 40) and am not in to drawing attention to the car etc but these few mods have made a big difference to the cars economy and I certainly feel there is better throttle response (and great handling as well). This is only my opinion though.
#27 | |||
