Cars for Sale Complete or nearly complete Cars for sale. Note: ALL transactions in these forums are done at your own risk. FordForums Australia Inc. does NOT take responsibility for any aspect of any item or transaction that may take place via the site. |
Isn't it obvious?
![]() Join Date: Nov 2009
Vehicle Sales Form State : SA Make of vehicle : Ford Model of vehicle : Falcon Year of manufacture : 1975 Colour of vehicle : Mushroom Beige Engine : 200 Transmission : 3 speed column manual Body style (sedan, wagon etc.) :Sedan Selling Price $ : 15000 Odometer Reading : 106000 City : Barossa ************************************************** ***************** Other relevant information. 1975 XB sedan 200 Hi Comp 3 speed manual column shift all synchro saddle trim mushroom beige paint original motor done 106000 on the speedo, the book has service history up to 68000 i am the third owner Currently the car is semi dismantled motor and box still in, loom still in, brakes and suspension all untouched, car rolls and turns by hand fine, motor has no battery, fuel tank still in, column lock still works. Condition rust above the rear tail lights, not major just the top section of the light surround still have the tail lights and they are uncracked, one side has a small piece of tin(?) rivetted across the rear screen on the edges down the middle has rust and would need to be repaired, the bottom screen corners aren't terrible but will need repairs as well side sills have a little at each end but certainly not bad at all by any means doors are on the car but not perfectly aligned doors have had small bog repairs in the corners on the front sides but nothing is thru the whole door, surface rust only on the undersides of a couple of them, close up to see the worse one which isnt bad at all inner sections under the guards have a little rust but nothing major under the hood seems to be free from any bad rust floors look good from above and below and sounds solid rear parcel is great (can just see a little surface coming up in that 4th pic from underneath which will correspond to the rear screen corner) Boot and fuel tank look clean Guards prob look the worst rear boot wells will need a small repair as well from what i can feel, but nothing bad by any means front grille has the tabs busted like usual, threes also a crack in the centre of the nose, nothing a plastic welder couldn't fix, the chrome strip on the grille edge is still there and fine, both honeycomb pieces all in tact all the fins are fine, headlight areas fine, just the crack in the nose and the inside tabs are bad crash pad is excellent, no tears or marks at all doors skins good also have a GT bonnet to go with the car, its dark green in colour and needs a repair on the end, have a pair of scoops and a set of pins have all inner and outer door handle bits, all work all latches, both sunvisors, the front seatbelts, the original headliner i have, carpet was gone and had to be binned, have front inner footwell covers, all glass is wrapped, have both rear qtr windows, all winding mech, all wipers, wiper bottle, battery tray kept all the rubbers and the door felts, some could possibly be cleaned up and reused. have the dash surround, the speedo and fuel gauge, the glovebox, all stored clean and in very good condition have the original crash pad which is a 9 out of 10 no rips or scuffs have the windscreen chrome surround with the rear still being in the rubber on the rear screen have the black/chrome side strips that go across the door centres have the plastic door sheets from behind the door trim both bumpers very good no dings, little surface speckle in some parts have a pair of front and rear over riders, rubbers good on all but one which has the lug snapped off from the back but can still be used back seat rear top has gone but base is fine front bench has splits on the drivers side, tops of both sides of front bench and base of passenger side front bench are good (from memory) front indicators good glove box good boot very good still has the jack sticker on it have a jack for it, have a spare that came with it have all four fairmont hubcaps have the headlights and brackets please don't low ball me i'm not in a rush i'm not letting it go cheap yes im open to decent offers around WHAT IM ASKING i've had it for around 11 years genuine buyers only please please dont message whats the lowest etc, ill just ignore it ![]() ************************************************** *****************
08 Strike G6E T. 10 Ergo G6E Sept 75 XB Falcon in mushroom beige, 3 on the tree 200cid for sale, offers in the teens |
Isn't it obvious?
08 Strike G6E T. 10 Ergo G6E Sept 75 XB Falcon in mushroom beige, 3 on the tree 200cid for sale, offers in the teens Last edited by MercurySilver; 02-04-2024 at 05:55 PM. |
Isn't it obvious?
cant edit posts after 30 mins so ill add another
(mods/admin please amalgamate as you see fit) and thanks to those that helped with image upload info (very helpful) heres a link to a gallery with some pics of whats in the description https://postimg.cc/gallery/3HxYVYTc any questions i can always chuck up more pics cheers merc
Looking for clues...
2016 Ford Falcon FG/X XR6 Turbo you beaut ute 1985 XR4Ti Sierra 1971 Fairlane 500 and... a collection of Jeep Towpigs and... two collections of rust and some new plastic bits roughly shaped like an F-Truck and.... some spare metal bits with holes in them |
Isn't it obvious?
would take ten
Isn't it obvious?
$5000
