Old 31-03-2025, 08:52 AM   #1
None-ya
Default Fish tank pumps advice
To put it simply how the H**L do I figure out what size pump I need ?
The tank itself is 151L×47H×46W cm, online calculator tell me 320 litres ( is this right??) if so can someone give me a idea of what size pump I'll need ???
. . . I hate math
None-ya is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2025, 05:31 PM   #2
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
Default Re: Fish tank pumps advice
Yes total volume is 326 L using your measurements, but you don't want to overfill it. So say the total height of water is about 4 cm from the top (height 43 cm), then effective volume is about 298 Litres. Probably a few litres less than that, once you put in sand etc.
Heaps of info online, do heaps of reading. All depends on what you want, and how fanatical you are about it. You can go from very high maintenance (almost daily) to very low maintenance.
Here's a few tips:
The novelty wears off after 6 months, especially if you cant get the balance right. The tank gets dirty quickly, and you start losing fish. Always the main problem is having too many fish. They sh!t a lot. Then you feed them too much, and they sh!t even more. That's why the tank gets dirty quickly, too much faeces, and wasted food. Cant be helped when you have too many fish, the dominant ones eat everything and get fat, while the shy timid ones get very little and slowly starve.
Snails are nice, but don't expect them to keep the tank clean for you, same for bottom feeding "catfish", they will never compensate for an over crowded tank, (no matter what the sales person tells you). So people get bigger, expensive, complicated (and often noisy) filter systems thinking it will keep the tank clean. It does work, but it become very high maintenance, and you need to know a lot about it, some people just love it.
So the secret is to have just a few nice fish. In a tank that size, maybe just start with half a dozen at the most, until you get good at it. At least 50% of the beauty of a fish tank, is having healthy thriving water plants nicely arranged, so concentrate on getting the plants growing well, and the rest just follows. In a poor set up, the plants always struggle and look terrible (sickly looking and covered in algal growth etc).
Size of the pump and filter? All depends on how much noise you can handle, and how much fish faeces you need to deal with. A few healthy happy fish can last 5 -10 years and even longer, depending on the species, with just a modest air pump/filter setup. An overcrowded aquarium and you will be constantly replacing the dead ones, and constantly cleaning the tank.
AMB is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2025, 05:42 PM   #3
Captain Stubing
Looking for clues...
Captain Stubing's Avatar
The minimum pump I would use is 4x (tank volume) per hour, so I. Your case nothing less than 1200 litres per hour. More is better, but that was the rough guide I would use.
Then you can decide on an off the side of the tank or an external pump and filter.
2016 Ford Falcon FG/X XR6 Turbo you beaut ute
1985 XR4Ti Sierra
1971 Fairlane 500
and... a collection of Jeep Towpigs
and... two collections of rust and some new plastic bits roughly shaped like an F-Truck
and.... some spare metal bits with holes in them
Captain Stubing is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2025, 12:18 PM   #4
None-ya
Going by the captain and the idea in my head I might look for 2 600LpH submersible (?) pumps/filters. Somewhat reason is 2 outlets at a different height might/should create more but less of a ' current (?) in the tank, 'hurt brain thinking ' one high in tank (main oxygenator (?), second placed more low then middle height ( more main filter for the faeces and what not).
I'd forgotten about snails. Was only planning of half a dozen fish at most,2 eal tailed catfish or two golden perch as the bottom feeders. And a few spangled perch,
maybe a couple of crayfish/ yabbys. Yeah this is freshwater
Gravel bottom 4-6cm deep.
I know there's still, lighting, heating, plants/weeds/ algae growth. . . Which I need for the fish I what.
. . . Yeah
The main thing that did/ doing my head in is the litres per hour as AMB stated it won't be filled to the top I was thinking to the 40cmH mark (just a nice even number) with 5ish cm of gravel. Il just stop now
