#811 | ||
Ok so running a recore
Mine currently does not want to work :( I get a strange error coms error when I hit recore Elm327 cable does quality matter tried in hs and Ms mode but no luck Also for some reason my radio station with blank screen icc, on my cluster it self it shows up as audio Off but music is playing my cluster is all working before Does this mean my unit has died completely and not just a simple recore flash is needed |
#812 | |||
#813 | ||
I managed to play with this some more today so far I have used
repair.ino.elf it has output a repair.log and dumped the folder and files contents.I think What i need next is a good copy of the files. |
#814 | |||
here is commands in case you just get heaps of scrolling text of stuff trying to start up.
#815 | ||
#816 | ||
Ballad of a dead man
#817 | ||
Today I had a look at what is going on with Boosted_g6's ICC
It was spitting a error about no partition been found where all the package files are stored I take it there is 2 partitions one for the QNX environment and the second one for the packages and scripts. I took the liberty of removing the flash chip to see if the environment would load to make sure that the environment wasn't being run off the arm chip. well I confirmed that there is 2 partitions on this chip. the environment part must not wear out like the scripts part of the chip as someone has said it would be from constant writes onto the flash memory that is wearing them.few weeks from now Ill order a BGA63 jig to read the drive raw onto the computer.then I will also order some new chips and see what I can achieve getting this running again. |
#818 | ||
Hey jason i did a bit of reading on how you recovered dead icc’s i’m interested in having a go at repairing mine, i have a field in repairing circuitry, i want to know abit more on what goes on and how to go about fixing my icc, is there any way i can pm you or some other form of messaging you.
Or if someone wants to tell me what actually fails on the board and what software os required to get the icc to work again. TIA Nick Last edited by Fgmk1; 19-11-2024 at 10:20 PM. |
#819 | |||
Regular...with metamusal
![]() Join Date: Oct 2009
you can click on the members forum name and send em a pm that way. |
#820 | ||
For anyone that comes looking and wants that instrument cluster software that Jason made, here it is: https://mega.nz/file/VS1hnbiA#G0SUaf...1G6F1B_1X5FPKk
The functionality to edit the odometer has been removed, and I've left several landmines for would-be reverse engineers. Have fun!
testerPresent Diagnostics & Software | Github Profile Jakka351 | Fg Falcon Git Repo | email:jakka351@outlook.com |
