Old 06-11-2022, 07:45 PM   #61
NCII40
XR6T BA 2002
NCII40's Avatar
Default Re: BA BF C5 325mm Brake Kits cheap
Originally Posted by FLOORED View Post
The offset of the disc is also different from the two rotors . The C5 BA Ford GT or PBR optioned kits are better as the caliper is also more rigid.
325 x 32 C5 Disc
322 x 28 XR6T XR8 disc
here are some pics for comparison
XR6T 2002 BA
Old 17-04-2024, 07:27 AM   #62
NCII40
XR6T BA 2002
NCII40's Avatar
Looks like they made a return
Hopefully the bolt holes line up
i will buy a set for trial
XR6T 2002 BA
Old 17-04-2024, 08:47 AM   #63
FLOORED
Race Brakes Sydney
FLOORED's Avatar
The bolt holes and offset won't line up because they are for a Chev and not a Ford. The caliper cradle (some call it a bracket) is different for each car eg HSV , FORD and Chev along with the Toyota they fitted them too.
Wjhat we may be able to do is use them for the 355mm kits we used to do back in the day if they fit the 32mm disc.
MATTHEW PEARCE
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 17-04-2024, 07:30 PM   #64
NCII40
XR6T BA 2002
NCII40's Avatar
Lets do this !
XR6T 2002 BA
Old 18-04-2024, 08:56 AM   #65
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Lets do this !
When you get them you can send a pair to me and we will have a look.
MATTHEW PEARCE
Phone 02 9609 1101
Old 18-04-2024, 08:00 PM   #66
NCII40
XR6T BA 2002
NCII40's Avatar
Thanks Matt
Update, It's Powerstop that are making them
Power Stop calipers and the brackets are remanufactured in our Chicago, IL facility
Power Stop calipers are 100% pressure tested to verify piston operation and prevent any possible leaks from occurring. This insures that every caliper is inspected for quality and safety. Every caliper kit is expertly assembled using new pistons, seals, slide pins (where applicable), dust boots, bleeder screws, and stainless steel brake pad abutment clips. High temperature EPDM rubber dust boots and premium silicone lubricant.
XR6T 2002 BA
Old 24-10-2024, 08:49 AM   #67
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Thanks Matt
Did you get them at all ?
MATTHEW PEARCE
Phone 02 9609 1101
Old 12-12-2024, 04:11 PM   #68
Cobra
Bear with a sore head
Cobra's Avatar
Do you think these might work if you used the Ford caliper brackets on them? Or is there more to it than just using brackets (of course assuming the brackets and slides mate correctly to the caliper)?
Cobra is online now   Reply With Quote Multi-Quote with this Post
Old 13-12-2024, 09:36 AM   #69
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Yes they are different
MATTHEW PEARCE
Phone 02 9609 1101
Old 15-12-2024, 06:20 PM   #70
Cobra
Cobra's Avatar
Smile Re: BA BF C5 325mm Brake Kits cheap
So, what do you think would be needed to fit these calipers then? I am very keen to replace my FG calipers so that it can accept a larger disc, but I do not want to go Brembos and have to swap wheels. The Territory Turbo calipers do not fit FG, do you think there's any other option now or in the future?
Old 16-12-2024, 09:32 AM   #71
FLOORED
Race Brakes Sydney
FLOORED's Avatar
The "Power stop calipers" ? i would have to look at them and see how they are built but i would say a custom caliper bracket.
We have done this in the past and found the caliper to use on a 355mm disc but it is now out of production. We have had a few other options in mind although some require a rotor mod which we prefer not too do. A custom bracket for the caliper is best but trying to find a caliper to suit certain rotors is a taking time.
The Power stop calipers might be the answer and a AFF member was going to buy a pair and send them but that hasn't happened as yet.
I may start looking into this or a similar kit again if it gains traction.
MATTHEW PEARCE
Phone 02 9609 1101
