#61 | |||
![]() Re Cam bolt, i've been watching Allan Howatt videos a lot. He reuses the cam bolt. This is where i am at now. -Flywheel locked in position. -8 New rockers placed -the area cleaned from rocker metal fragments. Next Stage -Fit the 2 cams with chain in correct position as per the diagram in my previous post (mark on intake cam pointing 12 oclock - mark on exhaust cam pointing 11 oclock) -Place the cam belt sprocket in correct position making sure the hole in the sprocket lines up with hole on the engine. -Place the timing belt and tensioner back on. -Then remove the pins and by hand spin the crank 2 rotations and check if both flywheel and cam pully both line up again and able to pin them again. All this before putting the rocker cover on making sure the marks on the cam sprockets also still line up at 12 oclock and 11 oclock. At the same time making sure nothing is hitting the rockers or valves while spinning. Any resistance or knocking sound while hand spinning would be a warning sign i don't have things right. Make or break time..... Literally |
#62 | ||
I’m relieved it’s coming together. Be sure to hit that torque - with thread locker - before your test turnings-over.
We did some bolts yesterday on a truck head that were 59Nm plus 90° plus 180°. It’s disconcerting to both consider how far you’re twisting it and how tight it’s getting - but evidently parts are designed to take the stresses. You should “overpull” slightly on the 60° as the bolt will naturally spring back. |
