Old 27-05-2024, 07:55 PM   #1
Luka
Default Brake testing for Blue Slip (NSW)
Gonna be taking my 97 EL Gli falcon in for a blue slip check in prep for rego in a few weeks. Just wondering the brake tests they do? I imagine they check brake pads and rotors, but what about calipers? One of my rear calipers rubber boots is damaged (I should replace but can't be bothered to fix/replace the brake calipers for this car (it's a skid car)). I'm hoping they just do some sort of test to measure the brake effectiveness because the brakes do work fine (pads need replacing, rotors goods, no noises or pulling of the car when braking). Just don't wanna throw money i don't have to at a car I plan on thrashing anyway.
Luka is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2024, 08:05 PM   #2
Default Re: Brake testing for Blue Slip (NSW)
If it (a damaged or defective aspect) can be seen through the wheel or on the hoist, then yes, it should be pinged on that detail. Pad material thickness and tyre treads will be examined more rigorously than for a pink slip.
Bear in mind that every feature a particular car was delivered with, needs to work for a blue slip - so if it’s got factory fogs they have to work, even though foglights are not a legal requirement overall.
