18-12-2023, 05:02 PM | #2821 | |||
20-12-2023, 11:24 AM | #2822 | ||
Rob
My carpro ech20 is getting low. I mainly use it diluted as a spray and wipe quick detailer on my bike and even more diluted as a rinseless wash on my caravan.
Is there another product that can do both jobs or should I look at just getting 2 different products that specialise in each specific area. Ech20 is nice and easy to use and leaves a reasonable finish (hard to really tell because my bike and van both have a high gloss finish anyway) but just interested in maybe trying something else.
UA2 TREND 4WD BI TURBO |
20-12-2023, 06:41 PM | #2823 | |||
And even if you don't like the idea of rinse-less washing, having a product like this on hand is very useful. I have both ONR and ECH20 mixed up at the Quick Detailer ratios for door jambs, interior dusting and engine bay wipe downs. They make good clay lubricants and drying aids, some can also be used on glass. I even put McKee's N-914 in the windscreen washer bottle as it softens the water, offers slickness between the wipers and glass, all while being much nicer than the aggressive windscreen solutions on the market. With ECH20, that is basically the slickest and glossiest rinse-less/waterless wash on the market. Compared to most others, ECH20 leaves behind a small amount of protection in the form of wax and Si02, so this is why it really excels at tactile elements. In actual fact, the wax element was mainly for lubrication apparently. If you like the feel of ECH20, the closest competitor would be Opti-Coat No Rinse, otherwise known as "Yellow ONR". This version of ONR has Si02 in the formula and has the most delightful mango scent. At 256:1 for rinse-less washing, it appears to be a touch easier to work with compared to ECH20. For waterless washing, mix it at 128:1. It is expensive at full retail, but ZAS have it on special at the moment for $23.50, basically half price. https://www.zas.com.au/product/955/o...nse_473ml.html https://detailingshed.com.au/product...ea012c06&_ss=r The next slickest is P&S Absolute. This is my favorite and the one I grab most often for its ease of use, slickness, the coconut-lime scent and the way it plays with other P&S products. The only thing to be mindful of is the mixing, this is quite a gloopy/lumpy product that needs some technique to get the best from it. I've been told that you should gently shake the bottle before measuring out the dose, be too vigorous and you will alter the polymers. You may also find that it tends to settle on the top of the water, from experience I've found using warm tap water and a gentle stir with your hands to alleviate that. Absolute was designed with ONR in mind, so the same dilution ratios apply, 256:1 for rinse-less. https://www.detailstore.com.au/produ...0f6b5bbd&_ss=r https://autobuff.com.au/products/p-s...e&_ss=e&_v=1.0 The other one to look at would be the above-mentioned McKee's N-914. While they won't say this, but being a surfactant rather than polymer-based product, it's basically soap. Personally, I prefer the feel of polymers and the slicker feeling they bring, but N-914 does seem to have a touch more cleaning power. https://autobuff.com.au/products/mck...4&_ss=e&_v=1.0 https://www.detailstore.com.au/produ...39575325147191
20-12-2023, 07:26 PM | #2824 | ||
Rob
Thanks, as always.
Sounds like sticking with Ech20 might be the go. I would probably still baulk at rinseless on my car, even though my car is worth significantly less than my van. I use it on the van mainly due to convenience. It's parked on dirt so rinseless makes less mess, and I don't have a hose long enough to reach. I use it at 1:10 on my bike and it works well.
21-12-2023, 07:48 PM | #2825 | ||
I've been sitting on this for a while, but this is a warning for anyone with MIRCH Grime Off in their collection...............
That is chemical etching after using the product, something has basically ruined the finish. Polishing a test spot yielded no improvement. I will never buy products advertised on social media ever again. Sure, the bottles look nice, and the brand is well presented, but this is typical of the "Facebook Brands". In that I mean a company set up by an individual to sell catalog products from a local blender, then advertised on social media and most likely "warehoused" in someone's backyard shed. And because these companies don't make or have any clue what's in the products, they and you have no recourse. I have not reached out to MIRCH, they would likely point to user error. In no way was the product used improperly, such as on hot wheels or in hot direct sun. It was used in a spray, agitate and rinse fashion. And I've used various similar products without issue for many years.
5 users like this post: |
21-12-2023, 11:38 PM | #2826 | ||
Damn that sucks! But I think you should send them a message. You are right - they will probably blame you. But point them to this thread if they want to get an idea of your techniques and experience with this stuff.
What have you got to loose - they may surprise you with a response? (probably not tho ) Imagine if it was a customers high end wheels that you used this on??
Daily Driver - FG GS Ute Toys - 351 XY Falcon and FG GT |
21-12-2023, 11:49 PM | #2827 | |||
Rob
I would be too. I also think it's worth giving them some feedback.
22-12-2023, 07:46 PM | #2828 | |||
For $300 cash, I'm going to overlook the two small nicks on one wheel and the missing center cap. I have already ordered a replacement cap and a bottle of Armour Detail Supply Wheel Coating from the USA, the same coating I used on the XR6 a few months ago, very happy with that coating. The plan is to wash and decontaminate the wheels, removing the old wheel weights and adhesive. I'll then polish them up, have new rubber fitted, then ceramic coat and fit the wheels. I could probably re-use the Dunlop's, but they are the original OE fitment and are over 7 years old now, so new tyres are probably a smart move anyway. Going to do Michelin Agilis in the factory 215/70/R16 size. And I'll probably end up doing a full wheels off detail. Washing in my driveway, I always get that smart ar.e neighbor or passerby who likes to drag out that "you'll wash all the paint off that car...." comment. Well, I guess that's what I did with these wheels! The chemical burns were the straw that broke the camels back if you will.
26-12-2023, 03:22 PM | #2830 | ||
Well done!
26-12-2023, 03:49 PM | #2831 | |||
Thailand Specials
What would you suggest for getting rid of serious amounts of oil/grease? Is there any particular product? I've been using Kenco degreaser undiluted under my ACCO and it worked alright for a quick 10 minute rush job with the cheapo pressure washer, but is there anything very effective you'd recommend instead?
I'm pretty sure that thing has never seen a wash underneath in its 25 years, its a mix of 20+ years of dirt/concrete/oil/grease Quote:
Kenco degreaser and the pressure washer worked a treat - took the paint off the wheels and started taking a layer off the hub Oops In this particular use case with the wheels, is this something you'd use a product like 'Iron X' on? In future I might get them either powder coated for a more durable finish or repainted. Last edited by Franco Cozzo; 26-12-2023 at 04:01 PM. |
26-12-2023, 04:10 PM | #2832 | |||
I've been loving Bilt Hamber Surfex HD for this sort of thing, its water based so much nicer to work with. But..............you will have to order it. https://www.detailstore.com.au/produ...a4d16c33&_ss=r https://www.ppcco.com.au/products/bilt-hamber-surfex https://autobuff.com.au/products/bil...aner-degreaser I use it at 1:1, which is very strong, but it can actually be diluted out to 200:1. From this................. To this................... Most of that cleaning was done by soaking the oily parts with Surfex, then rinsing clean. The other option would be to get some alkaline wheel cleaner. If you can find somewhere with Meguiar's Non-Acid Wheel Cleaner D143, that would work in a similar manner and its available in gallon sizes. Or Meguiar's Super Degreaser D108. https://www.repco.com.au/oils-fluids...SABEgICPfD_BwE Repco have the RTU version available - https://www.repco.com.au/car-care-pa...heel%20cleaner
26-12-2023, 04:15 PM | #2833 | |||
26-12-2023, 04:18 PM | #2834 | ||||
Thailand Specials
What I'll do is probably go the 5L Surfex and then get under there with the spray bottle and spray the crap out of everything and let it sit for a while then pressure wash off, I've got to squeeze in between the two diffs to get the tail shaft and the other side of the diff housings. The idea is if I can get it all clean then I can keep an eye on where new oil leaks are coming from and sort that out. While I'm here, have you heard of Batch Products before? They're a group of chemical people based in Melbourne's northern suburbs, they make this hand cleaner called 'Soft Hands' which is the best hand cleaner I've ever used, its unbelievable. They've got a large range of car care products, thought it may be interesting to you: https://www.batchproducts.com.au/car/ This is their 'soft hands' product: https://www.batchproducts.com.au/soft-hands/ Its got me clean as after being covered in oil and grease like nothing else I've ever used, also has no chemicals for those of us who suffer from dermo if you just as much as look at your hands wrong, its a bit pricey but you don't use much of it and it works unbelievably. Quote:
26-12-2023, 04:26 PM | #2835 | |||
https://autobuff.com.au/products/mar...p-sprayer-2000 https://www.waxit.com.au/products/kw...20409645891673 https://www.waxit.com.au/products/kw...20034637135961 I would still dilute Surfex, even at 1:1 / 50:50 its very strong. Some of those Batch Products look very familiar, not the branding itself, but I'm sure they are either supplying or are being supplied by a local chemical blender.
26-12-2023, 04:41 PM | #2836 | |||
Thailand Specials
26-12-2023, 05:17 PM | #2837 | ||
It wouldn't surprise me if those products were the source of the NV brand chemicals.
26-12-2023, 06:55 PM | #2838 | |||
Cabover nut
or clean them down, strip and re paint with Chromebrite.
30-12-2023, 09:36 PM | #2839 | ||
Repco have a 25% discount on their selection of Gyeon products at the moment.
https://www.repco.com.au/search/?text=gyeon If you are on the fence about Can Coat EVO, now would be a great time to grab some while on sale, a saving of $21.25 on full RRP. https://www.repco.com.au/car-care-pa...kwSearch=gyeon And if you are new to Gyeon, the Experience Set is on clearance and a great way to sample to range before investing in full size bottles. Included in the set is Bathe+, Wet Coat, Quick Detailer, Ceramic Detailer, Tire Express, Tire Cleaner, Restart Wash, Q²M Iron & Q²M Tar. https://www.repco.com.au/car-care-pa...kwSearch=gyeon
05-01-2024, 12:01 AM | #2840 | ||
The hose on my Karcher pressure washer (I think its a K2?) has driven me mad ever since I bought it - I've never known a hose to kink so badly. I'd really like to replace it with a longer, more flexible hose.
Can anyone recommend anywhere in Australia that sells replacement hoses? |
05-01-2024, 09:40 AM | #2841 | |||
05-01-2024, 10:25 AM | #2842 | |||
Rob
As mentioned bunnings sell all karcher products. If they don't stock it they'll get it for you. I bought a 10m extension hose for my old k2 and then needed an adapter when i upgraded to a new k3. I don't find my hose kinks. Probably the opposite. It's quite heavy and a bit cumbersome as it wants to hold its form from being wound up.
05-01-2024, 12:24 PM | #2844 | ||
I would love a gun or hose or adapter for a K2 that is 360/rotating, am sick of untwisting the cord.
ex owner of: Mk1 Escort, Mk1 Capri, BA Falcon but Fordless at present and punished by having 3 black cars and 2 teenage daughters. |
05-01-2024, 12:53 PM | #2845 | |||
I should have been more specific - the hose doesn't actually kink (ie fold on itself) but I find that it continually coils on itself and will not lay out flat. I suspect that it is the way it is constructed with a hard-ish plastic and what feels like wire reinforcing inside, and it is the hose 'memory' that is the issue. I want something that will lay flat and be supple and won't coil up. |
05-01-2024, 08:29 PM | #2846 | ||
I have a Gernie hose that rolls up onto its reel so does the same thing when you roll it out to use.
All you can do is to roll and stretch it out into the sun before use for a few mins and it is ok. It is a pain as I have to anchor the main unit as you do it, as it stands upright and topples over as you unwind and uncoil. I use 2 x 10 litre filled car wash buckets to hold it there as I do it and make sure i am well away from the Car.
2004 Mercury Silver Falcon XR6T - 5 Speed 2017 Platinum White Mustang GT - 6 Speed 2022 Blue Thai-Special for Daily Duties - Auto |
05-01-2024, 08:42 PM | #2847 | |||
If it were me, I would be upgrading the hose and gun in one hit. This is easily done and ,you simply select the Karcher fitting when shopping so that it can be adapted to your machine. Waxit have put a lot into their pressure washing packages and single item upgrades to suit machines like Karcher's and Gerni's, where as Detailing Shed have a more pro-level focus aimed at higher end machines like Kranzle's. The reason why I suggest replacing both the hose and gun is that the gun allows for much easier use of the foam cannon, while also providing a swivel point to help limit hose bind. Waxit offer both 3/8 and 1/4-inch hoses. The 1/4 will be closer to the Karcher hose and will actually provide superior flexibility compared to the 3/8. You would go 3/8 if you are chasing high flow rate from a larger machine. For car washing, you need 12 to 15 meters to be able to move around the car without moving the machine. So, you would team this hose in 50 feet length (out of stock at the moment) - https://www.waxit.com.au/collections...40423069646937 You then need the hose adaptor kit for Karcher - https://www.waxit.com.au/collections...40509933518937 You would then need a M22 14mm 3/8 male thread quick connect (this then allows you to connect the aftermarket gun) - https://www.waxit.com.au/collections...40423881277529 Then team all of that with this gun package - https://www.waxit.com.au/collections...40413952901209 Or..................buy this kit with everything you need (with or without a foam cannon) - https://www.waxit.com.au/collections...40519310475353 Or..............buy a Kranzle K1152 (The best car washing pressure washer on the market with one of the best OEM hoses. Once you use one of these, you will fall in love!) - https://detailingshed.com.au/product...ull-mtm-bundle If you are still unsure, either PM me or send Waxit an email, they are usually quite helpful. It takes a bit to get your head around, but its actually pretty simple once you know what to look for. I also have a thread here on this subject - https://www.fordforums.com.au/showthread.php?t=11496392
3 users like this post: |
05-01-2024, 09:08 PM | #2848 | ||
05-01-2024, 09:41 PM | #2849 | |||
Ya don't slow down as you get older ... you just enjoy taking longer to do it ... better! |
05-01-2024, 10:52 PM | #2850 | ||
There is certainly a technique to rolling a hose (I do it several times a day), but the hoses supplied with most pressure washers are total junk and incredibly annoying to deal with. That applies to hoses on a reel or loose.
