Old 12-11-2023, 05:39 PM   #1
SIM1
Question Are these heater core hoses the right way around??
Hi,
I have been working on the cooling system on my 2006 ZC 3.0L V6 Ford Escape using the workshop manuals posted in the tech docs (thanks Russ!).
While doing so I noticed the diagram of the heater core inlet and outlet hoses looked like they might be installed the wrong way around. I've swapped them over but I want to be sure I haven't done something dumb. Links to photos of current configuration and screenshot of diagram from workshop manual https://fordforums.com.au/wsmpub/zcesc68/07-07.html included.
https://www.amazon.com.au/photos/sha...jY9vV5253A57iA
https://www.amazon.com.au/photos/sha...ZogwEymjTesaxL
https://www.amazon.com.au/photos/sha...v7ZiyzmiVnjul4
SIM1 is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2023, 05:41 PM   #2
SIM1
Default Re: Are these heater core hoses the right way around??
I've tried to post photos but they haven't appeared on the post as far as I can tell.
I've posted links to the pics on an offsite hosting platform (Amazon prime)
Old 12-11-2023, 05:56 PM   #3
Itsme
Experienced Member
Itsme's Avatar
Photos you can see clicking on the links, your hoses look ok to me.
cheers
Old 12-11-2023, 06:43 PM   #4
73 4V XB
Frankenford pilot
73 4V XB's Avatar
Have a read through this. Most guys find it very easy to use.
https://www.fordforums.com.au/showthread.php?t=11482048
Cheers Bretto
73 XB GT
Last of the Big Ports
73 4V XB is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2023, 07:13 PM   #5
SIM1
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 12-11-2023, 09:45 PM   #6
mad2
Regular...with metamusal
it will work without the [IMG] & [/IMG] tags. all you need do is copy the hotlinks for forums tag line [or what ever ya wanna call it] and then post it as per below. -
otherwise your posting worked well.
mad2 is online now   Reply With Quote Multi-Quote with this Post
Old 13-11-2023, 09:55 AM   #7
Interceptor
HSV - I just ate one!
Interceptor's Avatar
If theyre not rubbing on anything..... whats the problem?
Old 14-11-2023, 03:43 AM   #8
SIM1
I'm assuming there would be a problem if the inlet to the heater core was hooked up to the hose that is meant to be on the outlet and vice versa?
Old 14-11-2023, 05:23 AM   #9
To me, it does appear they’re transposed. That’s from looking at the bends moulded into each hose.
If it’s a “constant flow” type heater core, it’s not going to matter - it will heat the same.
Old 14-11-2023, 08:53 AM   #10
Interceptor
Considering a heater core is essentially a long length of pipe arranged inside a series of fins, its no different to drinking with a straw.....
Old 14-11-2023, 10:16 AM   #11
…Except you’re less likely to be concerned with who used a heater core before you. #backwash
Old 14-11-2023, 06:13 PM   #12
GTLEGEND
Does this diagram help?
Old 14-11-2023, 10:38 PM   #13
Although some take advantage of thermo-siphoning induced flow and then the hot coolant from engine should be preferably connected to the lower inlet.
