Old 23-10-2023, 03:08 PM   #1
malbaby
Default SBF 2V Intake Manifolds 1960-1970's
Are the original manifolds worth anything, or should I put them out for recycling.
malbaby is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2023, 01:06 AM   #2
oldgringo
Default Re: SBF 2V Intake Manifolds 1960-1970's
Can't comment about the cast iron Windsor intake manifolds, but the 4 barrel cast Iron Cleveland intakes flow an impressive C.F.M. - the dead weight is a bit of a killer though.
Both the Windsor and Cleveland cast iron exhaust manifolds are pretty average - both are prone to having the right manifold crack.
oldgringo is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2023, 07:47 PM   #3
Paull
P6 LTD
Paull's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For all the hard work performed around paint, trim, engine codes in the Classics section. General all round knwoledge and willingness to impart on others
The only Ford inlet manifolds that I have found to have some value are the 4 barrel large port square bore ones as well as the early (1973 & 1974 cast date) small port 4 barrel manifolds.
You might find some people interested in the XD & XE era ones (to match ESP's and the likes) but not really worth that much. Anything two barrel and late XC 4.9 manifolds are scrap value only.
Paull is offline   Reply With Quote Multi-Quote with this Post
