Hi all,
I changed the headunit from the factory Sony unit, to my Alpine ILZ702D last week. Install went easy enough - I used the Aerpro facia and wiring adaptor kits to make it all plug and play. Unit, steering wheel remote works, and the bluetooth is all working correctly as well. This unit will also do Android Auto via USB, the unit requires that the park brake wire is connected up to the car. In my last car I had this unit in, (2002 Mitsubishi Magna AWD) - the electronics where much simpler, and the loom I needed to tap into was just there / nice and close for the hand brake. Question for those that have done it, where is the handbrake wire that I will need to tap to, so I can get all the functions of the headunit again. The car wont have a hissy fit? I want to do some wiring tidy work (the adaptor loom is 51596165156.6M long, and fitting it all behind the dash was a tough call, but I got it all in there with some convincing.) I have planned out in my mind how I will sort this out when i run the USB cable to the head unit. |
PURSUIT 250
![]() Join Date: Mar 2009
Earth the hand brake trigger wire in the patch loom
Thank you
#5 | |||
Sent from my SM-G980F using Tapatalk
So I finally got around to pulling the head unit back out again, and earthing the handbrake wire for this.
I have the full functionality of the Android Auto in the car now - which came in quite handy when we was down in Perth a couple of weeks ago. (I know my way around the City easy enough, but it is handy when you want a specific place to get to) While I was at it, tidied up some of the wiring behind the dash, and changed out the USB cable and relocated the USB connector on the extension lead, so its easy accessible if I ever need at it |
