Old 29-05-2022, 09:16 AM   #1
stefcio007
Default Charging an EFB
Hi guys,
First car with an Enhanced Flooded Battery and want to make sure it’s healthy.
In terms of charging the car appears to treat it like an AGM battery but most charger instructions say you can charge an EFB the same way as a Lead Acid battery.
When you use your charger on an EFB do you choose Lead Acid mode or AGM mode?
2020.25 Focus SA ST-Line Wagon + DAP
2011 Focus LW Trend (Diesel) [sold]
2006 Territory SY Ghia (AWD)
stefcio007 is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2022, 12:17 PM   #2
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Default Re: Charging an EFB
Originally Posted by stefcio007 View Post
Hi guys,
EFB is just a beefed up version of a normal lead acid battery,
Lead acid use a different charge profile to an AGM, lead acid charge at a slightly lower voltage than what an AGM does, as in a few points of a volt - stick to lead acid profile IMO but I reckon much of a muchness.
Old 29-05-2022, 01:19 PM   #3
stefcio007
Thought so just curious. Will stick to normal lead acid charging whenever I want to maintain it then.
Old 05-07-2022, 05:02 PM   #4
stefcio007
For the record Varta recommended charging EFB the same as AGM. I can confirm this works. When my Start-Stop didn’t work and charging with Lead Acid mode didn’t work. When I charged with AGM mode start stop now working again.
Old 06-07-2022, 09:05 AM   #5
FoxtrotGolfXray 5.0
FoxtrotGolfXray 5.0's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Willingly providing technical info and documents, despite glitches.
Hey stefic, not sure if you found this page in your search, but it may be of some use to you.
Interestingly, the recommendation from Ctek appears to be to charge EFB the same way you would a standard lead acid battery.
Hope that helps.
https://www.oliverjobson.co.uk/cars/...ification/#efb
Labels are for jars, not for people.
Life is a journey, not a destination.
Daily: 2013 FGII EcoLPi in Winter White
Play: 2015 FG X XR8 in Emperor Show' N Shine thread
Gone, but not forgotten: 2015 SZII petrol Titanium Territory in Emperor
FoxtrotGolfXray 5.0 is online now   Reply With Quote Multi-Quote with this Post
Old 06-07-2022, 06:19 PM   #6
stefcio007
I took the information from here.
https://batteryworld.varta-automotiv...ge-car-battery
Since my battery is a Varta one seems ok to follow their guide.
I’m using a Noco Genius 5. Interesting CTEK’s condition mode can be used on EFB but Noco recommends to only use its Repair mode on lead-acid.
