08-02-2022, 11:40 PM | #661 | |||
On the face of it it's like you've pushed my face further in the mud and given me a bigger headache all at once...
But reading through the list I can see some clarity that kind of matches what I thought. My understanding on the BA you either had a knuckle with a fixed upper arm mount or an adjustable by cam bolt upper mount, which were on the XR's and FPV's. This would account for BA5A968A and BAT5A968A. I've seen the BAT part listed as adjustable. But that was stopped in BF. The XR's got a fixed upper mount, which I figure is BAF5A968D, but the FPV bit in the description confuses me. BAF5A968C would be the adjustable upper knuckle, because that's what's in my Force 6. Plus the standard knucle. Parts ending with B and E confuse me though. Something special about V8's and the Turbo. Given they had different diffs and half shafts, might have to do with the wheel hub. More splines maybe. But the FPV bit confuses me again. Just spitballing... Quote:
As a comparison the VIN on Dad's XR6 is 6FPAAAJGSW6Y61571, built 02/06. I'm having a problem where I'm getting insanely bad inner edge tire wear on the back tires. The alignment specs suggest the rear end is whatever whatever an XR is. If it comes back with the standard part it will leave me even more confused. XR's have less than half the camber as base models and a very different toe setting. Then I will have to work out why the camber value is wrong. Is there something very out of wack in the rear end kind of thing. And if its not the knuckle that is setting the camber the only other thing that it could be is the upper arm. But I'm told they are all the same. |
08-02-2022, 11:52 PM | #662 | |||
6FPAAAJGSW6L56587: RH BA5A968A LH BA5A969A Interesting next VIN drills down to two options but does not specify which one exactly possibly because the catalogue does not know exactly which one was put in your car. 6FPAAAJGSW6Y61571: RH BA5A968A or BAF5A968D, LH BA5A969A or BAF5A969D. |
09-02-2022, 02:10 AM | #663 | |||
[QUOTE=GTLEGEND;6679502]
09-02-2022, 08:16 AM | #664 | ||
[QUOTE=silverfern.kiwi;6679668][QUOTE=GTLEGEND;6679502]
sorry mate got picture off this forum but it does look the part[/QU That part I can get for $55 + freight which may be via courier as Aust Post will not send anything over 1M. If you need those clips they are $18 each also. Hope this helps.. Send a PM if you would like to order. |
09-02-2022, 02:03 PM | #665 | |||
Last question if I could... Are the upper rear control arms all the same? I always believed they were. But the only other things that could explain what I'm seeing is different length arms. |
09-02-2022, 03:29 PM | #666 | |||
11-02-2022, 02:22 PM | #667 | ||
Are these FG Rims still available new
Numbers on the back are 8R29-1007-KA I believe they are from an FG Tonner
A word to the wise ain't necessary, it's the stupid ones who need the advice. |
11-02-2022, 02:44 PM | #668 | |||
Yes they are, $440 each plus freight if required (guessing around $30 each in freight via Aust Post). |
12-02-2022, 04:36 PM | #669 | |||
Is that the right part number for them or is that just a casting number
12-02-2022, 06:36 PM | #670 | ||
Just enquiring if SY Territory Ghia rhs rear chrome outer weatherstrip belt line moulding is still available
Gassa |
12-02-2022, 07:24 PM | #671 | ||
12-02-2022, 07:31 PM | #672 | ||
15-02-2022, 11:55 AM | #673 | ||
Can you let me know the correct part number for this wheel
15-02-2022, 01:51 PM | #674 | ||
16-02-2022, 12:21 AM | #675 | ||
16-02-2022, 07:56 AM | #676 | ||
16-02-2022, 01:01 PM | #677 | ||
Hi, I'm looking for a new cabin air temperature sensor for a 2012 Ford Focus. Are you able to quote?
16-02-2022, 03:36 PM | #678 | |||
Also are you referring to the outside ambient temp sensor or the one that sits in the dash which is only for dual zone AC Auto temp controls or the one that sits inside the heater case? One controls Footwell the other face level.. Last edited by GTLEGEND; 16-02-2022 at 03:42 PM. |
18-02-2022, 06:28 PM | #679 | ||
Regular...with metamusal
Hi Legend
just a query with regards to parts numbers...... are the parts numbers the same for the BA/BF/SX/SY1 XR fog lights/covers?. Thanks & take care. |
18-02-2022, 06:38 PM | #680 | |||
The BA/F XR Fog light covers fit Territory SX/Y from 1/2/2004 to 1/4/2009 and all share the same SX15K233AA part number. Can get these for $54 plus freight if required. The Spot/fog lights are also the same as above. Part number RH: BA15K200A (obsolete from Ford), LH BA15K201A Can get for $150 plus freight if required. Last edited by GTLEGEND; 18-02-2022 at 06:44 PM. |
18-02-2022, 08:42 PM | #681 | |||
Hi & thanks for the quick reply back. nah sorry as i was only after confirmation of the part numbers as i wanted to be sure they were the same. which they are. Again many thanks |
18-02-2022, 11:14 PM | #682 | ||
another question for you
what are the costs for the cap of the washer bottle to suit the BA/BF/SX/SY etc etc. postage to vic 3220. Thanks |
18-02-2022, 11:45 PM | #683 | ||
20-02-2022, 09:24 AM | #684 | ||
Barra Turbo > V8
Availability of this panel.
Also just checking again availability of XR6 badges for the sides of FG Ute
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels Last edited by DJM83; 20-02-2022 at 09:30 AM. |
20-02-2022, 11:40 AM | #685 | |||
As for the side badges they are currently out of stock but more coming soon. $70 each plus postage. I will see if I can get an ETA and advise. |
21-02-2022, 04:40 PM | #686 | ||
21-02-2022, 07:13 PM | #687 | |||
Barra Turbo > V8
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels |
21-02-2022, 10:46 PM | #688 | |||
I can keep an eye out and let you know or if you have not heard back from me by late March, give me a gentle reminder. |
22-02-2022, 08:40 PM | #689 | ||
Hi Need price for EB Wagon 7/91 Window Washer Bottle
22-02-2022, 09:39 PM | #690 | ||
