Old 03-11-2021, 08:33 PM   #1
Xr8panda
Default boss 290 rebuild
hey all just wanting to reach out im about to start a rebuild on my boss 290 xr8 its my first rebuild so im excited and nervous at the same time any advice or tips where to start? also im located in newcastle nsw is there any car clubs i can join around the area?
Xr8panda is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2021, 01:28 PM   #2
jakka351
jakka351's Avatar
Default Re: boss 290 rebuild
youll find the 5.4 workshop manual in the documents section of this site
jakka351 is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2021, 04:03 PM   #3
stevefreestyle
Just a couple of quick thoughts:
Have you stripped it yet to determine what needs replacing and machining ?
Are you doing the heads as well - Heads Shaved, valve grind and/or Guides etc ?
Apart from the obvious Rings & Bearings, make sure you replace the Timing Chain & Tensioners, and high volume Oil Pump - only with quality parts!
Your 2 most important tools are a Micrometer and a Torque Wrench
Make sure you do a thorough soak and clean (Diesel works well) of all components, and make sure your work environment is absolutely Dust Free (Spotless!)
Good luck with it !
Current: 2021 FN Mustang GT 10 Sp, Velocity Blue
Previous: 2017 FM Mustang GT
stevefreestyle is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2021, 04:34 PM   #4
stevefreestyle
This might help: http://www.fordforums.com.au/vbporta...articleid=1144
