Old 08-10-2021, 10:21 PM   #1
Jack91
Jack91's Avatar
Default Flaring tube bit not at the end of it
Hi all,
Very used to flaring steel and copper, but only at the ends. What is it called when the flare is a couple of inches in from the end (maybe more a collar than a flare), is this something a feller can do at home or does it require super specialised tools?
Jack91 is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2021, 11:51 PM   #2
Default Re: Flaring tube bit not at the end of it
Bead per:
You need a beading tool e.g. https://www.youtube.com/watch?v=nxZTe2Rs-X8
But various companies make cheaper one for less varied use e.g.:
https://www.ebay.com.au/itm/23398867...UAAOSwP3Fgi49s
https://www.ebay.com.au/itm/15347420...ure!6163!AU!-1
https://www.ebay.com.au/itm/32440139...4AAOSwTg9hOlzJ
Used this way: https://www.youtube.com/watch?v=O9hTleI8a9I
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 09-10-2021, 11:12 AM   #3
slowsnake
Originally Posted by Jack91 View Post
Hi all,
Is it for the brake lines, or high pressure like hydraulic steering, or is it just a water hose connector, what material...length, diameter, thickness....
slowsnake is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2021, 11:27 AM   #4
Blue Dog
As aussieblue has indicated above, it is called a "bead" not a flare.
Blue Dog is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2021, 11:10 PM   #5
Jack91
Jack91's Avatar
Brilliant. Thanks for that!
