As in title I have a 1999 WF Festiva Trio 1300 ..
Starts no worries when I leave home runs fine , get to where i'm going 15 minutes later turn it off do what I have to do hit the key turns over doesn't start , try to start a couple of times still no start , let it sit for 10 to 15 minutes starts again... Some days it doesn't have any troubles at all .. This showed up after the Heavy rain we had recently , but I sprayed the dizzy and an all other connection with WD40 and it started , next time it stopped and I sprayed again it didn't start ![]() I plan on taking some electrical wire with alligator clips and connect to the coil lead unplugged at dizzy to check for spark when I turn it over when it does it again ... Do these cars have a fuel filter that maybe clogging up ? Could the coil be close to Fried ? Any suggestions would be much appreciated as it's great running little car Regularly Maintained . Cheers ALL |
It may be a long shot but I used to have a Mazda that did exactly this. Turned out it was voltage drop in the starting circuit. I had a relay put in to make sure I got 12 volts from the key (small wire onto starter solenoid) and never had a problem again.
Thanks adyadad will look at that for sure ..
The older the car, the more likelihood of voltage drop. It's an easy job to do yourself. Just a normal small Bosch relay, some wire and connectors. 10 minutes max.
