Old 07-04-2006, 07:51 PM   #1
Qwikcorty
V8 Turbo Hoon
Qwikcorty's Avatar
Default quick question
ive blown the indicator globe in the right front of my xr8, how do you get to it to change it? cant see a way into the light at all
Qwikcorty is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2006, 08:08 PM   #2
LUXO_8
windsor user
on the regular sedans ( i presume its the same for the XR's) you have to take off the plastic trim in the wheel arch and access it from there...
there is no hole in the inner guard like on eseries....
Old 07-04-2006, 08:20 PM   #3
Qwikcorty
V8 Turbo Hoon
Qwikcorty's Avatar
indicators are in the bumper below the headlights.
Old 08-04-2006, 04:06 PM   #4
Pinkbits
Pinkbits's Avatar
Under the front bumper there is a plastic cover, undo 2 or 3 screws and slide your hand in. The globe holders should just twist to remove. replace in reverse order.
Pinkbits is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2006, 07:25 PM   #5
Mechan1k
Mechan1k's Avatar
same for normal Falcon headlights as well ... just not located in the bumper though ... need to access from the wheelwell behind the plastic inner guard like others have mentioned.
