Old 20-10-2012, 05:47 PM   #31
Birth
Default Re: Loose steering
Kryton, how much for your I6 one mate?
Birth is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2012, 10:25 PM   #32
hales231271
hales231271's Avatar
The I6 intermediate will work no problems.
The V8 unit has a collet welded on the shaft to accept the V8 heat
Shielding .
I have used I6 units on the V8 and adapted heat shield using a press collar.
I6 units are dime a dozen at the wreckers and seem not to fail as the V8
Unit due to exhaust heat.
Easy to find a good I6 intermediate unit for a cheap price.
Dazza
hales231271 is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2012, 11:13 PM   #33
b2tf
not here much anymore
b2tf's Avatar
Originally Posted by Birth
B2tf, did you find your V8 shaft in the shed? Thanks, Ben
Apologies for the delay in reply, couldnt find it. I had a big cleanout a few weeks back and it must have gone with it.
RAM 1500
Old 22-10-2012, 11:40 PM   #34
Kryton
Kryton's Avatar
$40 if you want it.
That includes the shaft and Uni joint as well.
PM me if interested.
Old 23-01-2016, 09:23 PM   #35
ZC Burgundy
Originally Posted by Mechan1k View Post
I am with Hales .... I had the same issue.
There is a bush with a pin through in ... and that bush gets that worn it cause so much play in it.
I got a replacement intermediate shaft from a wreckers in good condition ... for $70. from memory I got mine from FTG.
Fixed my issues perfectly.
Originally Posted by mik
there is an adjustment that pushes the rack shaft against the pinion , but from what i`ve seen of my own rack they don`t seem to go out of adjustment much, the thing i think that wears mostly on these racks is the inner ball joints and the o rings at the sealing ends of the rack, see if i can get a decent pic size up of the main workings.
Can the pin be welded?
i'm guessing the bush is there to dampen the steering..
ZC Burgundy is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2016, 09:25 PM   #36
ZC Burgundy
Originally Posted by hales231271 View Post
The play is usually caused by the intermediate shaft on the AUs.
Connects to steering rack.
Try this.
With vehicle stationary and not running grab the steering shaft in the engine bay and turn with your hands (just above the universal joint).Make sure the ignition lock is not on.
You may feel the "play" in the intermediate shaft.
They wear in the shaft pin.
Picture is from my worn out V8 intermediate shaft.I6 same but with smaller colller.
Rgds
Dazza
Old 04-01-2020, 12:55 AM   #37
NCII40
XR6T BA 2002
NCII40's Avatar
Originally Posted by Kryton View Post
So it turns out it isnt the uni joint after all.
The bolt that holds the column to the uni joint had fallen out at some point which is where the play was.
Put in another bolt and its all good.
Got any pics ? or a guide where to look for the missing bolt
XR6T 2002 BA
Old 06-01-2020, 10:47 PM   #38
NCII40
XR6T BA 2002
NCII40's Avatar
True, Six and Eight is same Intermediate Shaft
The only difference is the V8 Intermediate Shaft has a welded on collar, bigger Bell and Heat shield Foil wrapped around it from the Factory
Slide off the Heat Shielding Foil and Grind off the welds that hold the collar on and bigger bell in place on the V8 Intermediate Shaft, and it will slide straight off
Slide on the Collar and Bigger Bell onto the 6 Intermediate Shaft and tack weld that on
Take note of the position from the V8 Intermediate Shaft, mine was 210mm down to the top of the bell
Slide back over the heat shielding Foil and your ready to go
XR6T 2002 BA
Old 08-01-2020, 10:51 AM   #39
NCII40
XR6T BA 2002
NCII40's Avatar
Visual only on what they look like, left is what a 6 Cycl looks like and Right is what a V8 looks like
The V8 on the right has the larger bell and foil
the pic is fully converted, you can see where i have ground off the welds on the one on the left and swapped over the heat shielding and quick coat of paint black to protect the spot welds,
i just use a mig, arc welder would be maybe be fine, not sure
XR6T 2002 BA
