I read the manual it says 5w-30, but I am not sure if it is thick enough for such old car? 10w- 40 better?
And most of the time I am running Gas, should I go for special oil for a gas car? Please give me some suggestion, Thanks. ![]() |
I use Penrite HPR Gas 10w-50 in my dual-fuel AU1 Fairmont.
No issues. |
I ♥ EDM
![]() Join Date: Aug 2006
AU1s recommended 5w30, AU2s recommended 10w30, despite being the exact same engine
![]() Ill second Dr Jekkyls recommendation. A 10w Gas oil would be the best choice. |
rexnet
10 is for start up. 30 is for running temp.
i run a 10w30 and am pretty happy |
Flairs - Truckers Delight
where in the world are you alee79
because if you're a queenslander, you should be sticking 15w40 in your I6 all this 5w30 'water' ain't oil
10w40 here. No issues but petrol only.
AU XLS. |
Thanks guys. I am in syd. Looks like I should look for 10w...
Would people recommend Penrite HPR10 (10W50) in a '99 AU1 with around 250,000km's on the clock?
(I use HRP10 in my commodore so I'd like to use the same oils between cars if I can!). |
you could run 10w50 ok - but if you ask me, that'd be a bit thick when warm - you'd likely see less power and increased fuel consumption. personally i'd be really hard pressed to move away from 10w40 (cool states) or 15w40 (warm states).
#11 | |||
RIP...
. Oval Everywhere... |
#12 | ||
I use fully synthetic 5W30 I have found it to be the only thing to get rid of the famous AU lifter tick.
[SIGPIC][/SIGPIC]
#13 | ||
Anyone know what PRO50 is? That's what appears to be in the car now, according to the workshop receipt I found in the glovebox (they gave it a minor service before we took it).
I gather it's 10W50 already in there? |
#14 | |||
I just put a 5w-30 into my 650k XR6 and she burns it good, it was free. I usually put 20w-50 in there every 5k. |
#15 | ||
so even in chilly NZ you find 5w30 too thin smoo?
not surprised.
#16 | ||
Ta guys... I had a look at the Penrite book in Repco (making use of the 20% discount), and it recommended HRP5 for the AU series (which is odd, I swear the card in Supercheap said HPR10!).
I live in a colder state (Melbourne), so I'll try HPR5 first and see how it goes... I've gotten used to the sound of the engine now running whatever "PRO50" is, so I'll know if HPR5 produces any more ticking noises, or uses more oil etc (if it does, I'll swap it for HPR10 instead). I have all the gear for my service now and it's going in tomorrow, finally. |
#17 | |||
RIP...
You'll be fine with HPR5 anyhow.
#18 | |||
#19 | ||
Oh wow, 20deg, lol.
Yeah - you never rectified the fuel usage issue? I would have bought another ford by now if it was me.
#20 | |||
#21 | ||
Good man. the 'lane on gas? Probably not being nz rite? I assume it has the VCT motor too, but i have seen a gas lane taxi with a greentop in it...
#22 | ||
Fairlane is dual fuel, 70 cent/litre difference between gas and ulp here so any savings will be marginal, would prefer the boot space. Yep she has the frugal VCT
#23 | ||
Im about to switch to shell helix ultra 10w-60 (AU3 xr6 HP 148K on the clock) just because i got it for free, any one used it in an AU before?
Big dreams, not enough money ![]() Smoke tyres, not drugs ![]() ![]() |
#24 | |||
RIP...
#25 | ||
10w60? What? Why? In what possible application could that be a good thing?
10 is too thin when cold, 60 is too thick when hot! What's going on manufacturers?
#26 | |||
hmmmm what do i do with two bottles of the 10w-60? ![]()
#27 | |||
All Bran = Regular Member
http://widman.biz/English/Calculators/Mixtures.html |
#28 | |||
#29 | ||
After some investigation I'm assured 5/30 is good even for an older AU motor, they were the tightest motors ever produced by ford and have teflon coated pistons, in general they wear so well that wreckers have more low mileage motors in stock than they could ever sell due to the reliability and robust design the AU afforded.
