03-02-2019, 03:41 PM | #1 | ||
Hi all.
I'm trying to get my hands on some pre made trolley jack rubber pads with and without a slot. Or somewhere that sells thick rubber slabs so I can make my own. Clark rubber only sell 6mm strips which is way too thin. Any ideas? Sent from my LYA-L09 using Tapatalk |
03-02-2019, 03:43 PM | #2 | ||
Forgot to mention that I'm after ones that are 100-105mm diameter.
I've seen some on ebay that are only 50-65mm which is a tad small Sent from my LYA-L09 using Tapatalk |
03-02-2019, 04:10 PM | #3 | ||
Cabover nut
I've used old anchor bow roller rubbers as jack blocks before.
Boat or even truck docking rubber suppliers ?
03-02-2019, 04:12 PM | #4 | ||
Ice/Street/Roller hockey pucks are often used their standard size is 1 inch (25 mm) thick and 3 inches (76 mm) in diameter. Ice hockey requires the harder disks and these are usually made of vulcanized rubber. I have a variety of ebay purpose made jack pad and find many are too soft and cut then split where the weld seam rests on them (but the NC V8 Fairlane was no light weight). I now use ones that are aluminium with a magnetic piece and and nylon rest; these: https://www.amazon.com/PXPART-Univer.../dp/B07J9W3JRJ The magnets are great as you put them on the car seam weld first and there is no chance of getting the seam weld misaligned with pad/jack.
regards Blue |
03-02-2019, 06:15 PM | #5 | ||
Former BTIKD
03-02-2019, 06:34 PM | #6 | ||
2003 BA Falcon XT
I've actually been using wood offcuts to jack the car up from the chassis rails at the front, and diff at the back for years. So far so good!
2003 BA Ford Falcon XT IMPCO LPG Vapour Injection. DETAILING Meguiar's NXT Car Wash Collonite #845 Insulator Wax Bowden's Own Happy Ending & Fully Slick Chemtech CT-18 Truck Wash (Wheels & Chassis) Bowden's Own Wheely Clean & Tyre Sheen Bowden's Own Three Way Paint Decontamination Spray OILS AND FILTERS Nulon Full Synthetic 10w-40 Nulon Long Life Coolant Ryco Oil & Air Filters My Instagram Account: @ba_falcon2003
04-02-2019, 09:43 PM | #7 | ||
I have a Blue Point trolley jack which has a 140mm rubber pad. They are sold by Snap-on. You know, the tool guy in a truck that visits all the workshops.
I bought a replacement pad for my jack so they would be worth a try
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
04-02-2019, 09:47 PM | #8 | |||
05-02-2019, 08:49 AM | #9 | ||
Can't remember as it was years ago. The jack was purchased 10-15 yrs ago and cost around $700 I think so what the replacement rubber pad cost didn't matter. Its a very low and long jack that fits under T Series cars no problem and has about 600mm lift
11-02-2019, 09:17 PM | #10 | ||
If you don't mind the wait Aliexpress has plenty to choose from, like this one:
https://www.aliexpress.com/item/Blac...AbTest=ae803_3 Search for "jack pad" I got one from there myself and I get all kinds of stuff from Aliexpress, never had a problem so far.
My dream car/build: http://www.fordforums.com.au/showthread.php?t=11282132 |
11-02-2019, 09:19 PM | #11 | ||
I ended up buying a 100x100x50mm rubber block off ebay for $20 shipped. Will be cutting a slot in it for the sill.
