Old 28-11-2018, 07:17 PM   #31
Tassie f100
Default Re: Fuso truck
Originally Posted by hayseed View Post
Google "Driveline windup"........
That refers to transfer case Not main gearbox
Tassie f100 is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2018, 07:34 PM   #32
Tonz
bruce.lee5@bigpond, earlier I was a little blunt with you. I apologize.
Dont know where you are but seriously Dept Fair Trade, Consumer Affairs whatever it is in your state, go visit them. Be polite and warm to them, (they are public servants and need caring for )
Tonz is online now   Reply With Quote Multi-Quote with this Post
Old 28-11-2018, 07:38 PM   #33
buggerlugs
If it ain't broke........
Yes, might have a bit more success than coming on a Ford Forum and complaining about a Fuso truck...........
Visitors welcome
Relatives by appointment only
buggerlugs is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2018, 07:43 PM   #34
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
Maybe try head office and talk to them. You would think there should be someone there to talk to if the dealer refuses.
https://www.fuso.com.au/Contact
Otherwise speak to the consumer affairs in the state you bought it.
If you haven't given the go ahead to repair maybe have a look at someone else to rebuild the box if the other two fail.
Daniel
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2018, 08:12 AM   #35
hayseed
I would've thought, It'd apply to the entire Drivetrain & find the weakest link..!!!
But I'll defer to your superior Knowledge..
hayseed is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2018, 09:55 AM   #36
bruce.lee5@bigpond
Originally Posted by Ben73 View Post
ACCC covers products that die unreasonably early even if the manufactures warranty has expired. I would expect the transmission to last more than 91,000kms in any vehicle.
Thanks for the heads up Ben.....Have been in contact with ACCC and made formal complaint. Your right.....they say "it would be reasonable to expect more than 91000ks". Keep you informed.
bruce.lee5@bigpond is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2018, 09:58 AM   #37
bruce.lee5@bigpond
Thanks mate....it's Head Office who I have been talking to. Have now complained to ACCC.
Old 29-11-2018, 10:04 AM   #38
bruce.lee5@bigpond
Wink Re: Fuso truck
Thanks Tonz....No apologizes needed, have now gone to ACCC.
Old 29-11-2018, 10:20 AM   #39
Tassie f100
Sorry hayseed.It isn,t superior knowledge.For your info windup is when you try to feed two different ratios into the same ge****t. This is can be caused by running different size tyres front to rear. On a hard surface even the difference between new and worn tyres on different axles can cause windup.A lot of 4WD,s have slightly higher front diff ratios than rear,but on soft surfaces this doesn,t cause any problems. Once you get to the transfer to gearbox connection there is only one ratio involved,so no problem
Old 29-11-2018, 10:23 AM   #40
Tassie f100
It appears that any words with the letters a,r,s and e together get censored.
