22-11-2018, 07:26 PM | #1 | ||
Hi All,
Is anyone running the Ford Racing Z460? Thinking of going this way but I can’t find much feedback on their track results. Are they any good?
70 mercury cougar, 351c 4vcc NOS. BA XR8 Yella Terra blower. |
24-11-2018, 10:03 PM | #2 | ||
Turbo 358W
lots of cubes, but could do with a set of TFS highports like the 225cc or 240cc sized CNCed ones and a custom cam plus some more compression,
25-11-2018, 04:28 AM | #3 | |||
It might be perfect for your needs. It has some good basic hard parts in an under stressed mild build that will make good tractable power. One thing I would have done differently on the bottom end would be good I beam rods in the slow winding high torque application. That said, those H beams will work well in that under stressed combination. I see it was tested with a Super Victor intake. I tend to think in that mild configuration a cleaned up Air Gap would be a good. Might be worth a little research. Let me ask, what is the overall goal? |
26-11-2018, 05:10 PM | #4 | ||
Thanks guys, when looking at this combo with low compression and low on the RPM scale I was thinking it seemed a bit soft, the question is this due to the block being maxed out because of the cubes? I’m looking for a good strip engine that is still drivable. 600hp at the tyres would be nice with a heap of TQ. The price on these seems good and being a bit soft I thought would be good for reliability. 150 shot of NOS and I’d be close to target. I’d appreciate some build combination ideas for around the 20k mark.
26-11-2018, 08:35 PM | #5 | ||
Interesting. I’ve been considering the same motor for my ‘77 F100 to replace the tired Cleveland. I figured all that torque would be useful and as everything is new, it might be better than machining my aging block, assuming it can be reused.
26-11-2018, 09:07 PM | #6 | ||
Nice match for the F100 👍
27-11-2018, 01:04 AM | #7 | |||
I wouldn't go a pony over 150 shot with that block though. According to Ford the block is designed for a minimum cylinder thickness of .180" my old limit was .170" for 700hp in these kind of blocks. Of course, where that thin spot is makes a lot of difference. Is it at 3:00 and/or 9:00? or also 12:00 and 6:00? Side to side, no big deal. Thrust side, don't go over that 150 shot. In all honesty we took this approach with a Top Sportsman car. We got 3 of the original 600cid Ford crate motors and threw away the rods, pistons, dampers, cams timing set,. Did a little work on the old original A460 heads and bingo had 3 rotating motors. 1 in the car, 1 spare in the hauler and one getting a freshen up. Qualified every time and was usually in the top 4. Based on what your expectations are, I am going to recommend using what you found. I could work something up for you, but it will take longer to get and you will have to track more details on your end. |
27-11-2018, 01:40 PM | #8 | |||
Peter Car
I'd assume it's probably to make them reliable and keep the cost down, while providing a fairly smooth idle and reasonable fuel economy, while being able to run on lower quality fuels. |
