What is the tool I need to remove the retaining screws to take the airbag off the steering wheel?
Thanks, Wasim |
Great - Thanks
#4 | |||
You can't stop the signal
It's a Torx Plus Security bolt (5 point, centre post). It is odd as torx is usually 6 point.
If you use the screw driver method above, once you get them out you replace with Allen key bolts. The screw driver generally doesn't last. Or you can buy the specific bit. I know this SP Tools bit set has the correct one http://www.sptools.com/en/product-li...r-bit-set.html
XR6T BA 2002
XR6T 2002 BA
