Old 27-06-2018, 07:56 AM   #61
Default Re: Vaseline - do you still use it?
How did the song go?
Rich girls use vaseline
Poor girls use lard
Dinah uses axle grease...
I actually have a 10kg bucket of the stuff in the shed.
I recently built a low deck floor under my pergola.
I coated all the bearers and joists with it and also the underside of the decking.
Great stuff!
Old 27-06-2018, 08:02 AM   #62
Electrolyte Burns
It's perfect for smearing a bit on the insides of your radiator hoses etc. They will slide off perfectly many years later.
Electrolyte Burns is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2018, 08:21 AM   #63
Cav
HUGH JARSE
Cav's Avatar
I don't use the stuff.
I found that the opening wasn't rounded enough and was too small, and the jar wasn't long enough.
Cav is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2018, 08:24 AM   #64
FairmontGS
WT GT
FairmontGS's Avatar
FairmontGS is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2018, 12:59 PM   #65
Interceptor
HSV - I just ate one!
Interceptor's Avatar
The spray on protectors are crap, they only cover the top, and the corrosion problems you get are caused by the acid leaching up from underneath.
My favourite is pep korode-kure, though like most things, the newer stuff isn't half as good as it used to be
https://goo.gl/images/DTxbpj
Old 27-06-2018, 05:40 PM   #66
sprintman1
Don't, as petroleum jelly destroys rubber. Use silicone grease if you have too
sprintman1 is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2018, 07:16 PM   #67
pottery beige
use this stuff on hooses
https://www.blackwoods.com.au/part/0...-aviation-50ml
best
pottery beige is offline   Reply With Quote Multi-Quote with this Post
